586,036 active members*
4,343 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Alphacam Vba Create Surface
Results 1 to 8 of 8
    May 2022
    7
    Merhaba.
    Alphacam VBA ile iki çizgi ile Yüzey olu?turmak istiyorum.
    Yüzey olu?tumak için örnek program kodlar?na ihtiyac?m var.
    yard?mlar?n?z? bekliyorum.
    Apr 2015
    327
    Re: Alphacam Vba Create Surface
    Hello,
    check this code.
    Option Explicit
    Public Sub surfaceCreate()
    Dim drw As Drawing
    Set drw = App.ActiveDrawing
    Dim SurRec As Path
    Set SurRec = drw.CreateRectangle(0, 0, 1000, 500)
    drw.CreateSurfaceFlat SurRec
    End Sub
    https://drive.google.com/file/d/1jmF...usp=share_link
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    May 2022
    7
    Merhaba. ilginiz icin tesekkur ederim. istedigim 3D Surface olusturmak. Sizin orneginiz Flat Surface. 3dPolyLine ile yüzey olu?turmak istiyorum. 3dPolyLine ile Path yapamiyorum. bir video çekip atmayi deneyecegim.
    May 2022
    7
    3D yüzey örnek
    Apr 2015
    327
    In this case is code very similar.
    Option Explicit
    Dim drw As Drawing
    Dim SurPoly_1 As PolyLine
    Dim geo_sur1 As Path
    Set SurPoly_1 = drw.Create3DPolyline(0, 0, 0)
    SurPoly_1.AddLine 100, 0, 40
    Set geo_sur1 = SurPoly_1.Finish
    Dim SurPoly_2 As PolyLine
    Dim geo_sur2 As Path
    Set SurPoly_2 = drw.Create3DPolyline(0, 200, 0)
    SurPoly_2.AddLine 100, 200, 40
    Set geo_sur2 = SurPoly_2.Finish
    Dim tolerance As Double
    tolerance = 0.1
    drw.CreateSurfaceRuled geo_sur1, geo_sur2, tolerance
    End Sub
    https://drive.google.com/file/d/11CJ...usp=share_link
    May 2022
    7
    I've tested it.
    Thank you very much. Thank you very much. Thank you very much.
    May 2022
    7
    Dim Sf As Surface
    Set Sf = pC.CreateSurfaceRuled(geo_sur1, geo_sur2, tolerance)
    Sf.Redraw
    Sf.Selected = True
    mc.ChordError = 0.1
    mc.MachineSurfaces
    Sf.Selected command not select surface
    https://youtu.be/panGGGYZkYY
    How To Toolpath Surface 3dProject
    Apr 2015
    327
    Code should look something like this.
    Option Explicit
    Dim drw As Drawing
    tolerance = 0.1
    Dim M1 As Surface
    Set M1 = drw.CreateSurfaceRuled(geo_sur1, geo_sur2, tolerance)
    M1.Selected = True
    App.SelectTool App.LicomdatPath & "licomdat\rtools.alp\Bull Nose - 10mm x 1.5mm rad.art"
    Dim MD As MillData
    Set MD = App.CreateMillData
    MD.ChordError = 0.1
    MD.WidthOfCut = 0.5
    MD.SetSurfaceMCPoints 20, 20, 0, 30, 20, 0
    MD.SurfaceMCAction = acamSurfaceMCActionMCSURFACES
    MD.SurfaceMCMethod = acamSurfaceMCPARAMETER_LINES
    MD.MachineSurfaces
    End Sub
  1. AlphaCAM VBA
    By MR_67 in forum Alphacam
    Last Post: 12-13-2020, 08:40 PM
  2. Alphacam VBA
    By cckstone in forum Alphacam
    Last Post: 11-27-2019, 09:45 PM
  3. alphacam vba
    By zx6 in forum Uncategorised CAM Discussion
    Last Post: 04-01-2014, 08:18 PM
  4. alphacam Vba macros
    By zx6 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-01-2014, 04:06 PM
  5. need help in VBA alphacam postprocessor
    By basim in forum Visual Basic
    Last Post: 02-13-2010, 02:04 PM
