587,019 active members*
5,790 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > StyleCNC 6090 Table top CNC Router losing steps
    I purchased this machine new last year to mill inlays and pockets in pool cues. The machine does an okay job, but the accuracy/repeatability is lacking.
    Few issues I am having,
    After I set my work coordinate, if I move away and return it back to the zero, the position is off. I have had times where Mach3 has frozen on me and I had to restart, reset the zero and it would start cutting the pieces more on one side than the other. I also step down in tool size, .0625,.031 & finish with a .020. In order to make the pieces so they don't have a step, I need to leave material and cut the whole profile with the .020, which sucks because I have to go slower and take smaller cuts.
    I also noticed the rotary does not rotate back to the original zero, this is also causing me issues.
    Is there a way to reduce or eliminate the machine losing steps? I am at the point I want to remove the steppers and replace them all with something more accurate, just not sure what that would be.
    TIA
    Carlton
    Nov 2013
    4469
    Re: StyleCNC 6090 Table top CNC Router losing steps
    if its the steppers which are losing steps, and it is highly probable, then the only way to reduce the inclination for a stepper to miss steps is decrease the accelerations and max velocity.
    Reduce both acceleration and max velocity in Mach to 1/4, then slowly increase the acceleration until it starts missing steps, back off by 25%. Then do the same with velocity.
    What voltage is the power supply to the stepper drivers. A lot of Chinese CNC routers use TB66xx type stepper drivers and they can handle only 36V. With decent drivers running at 72V or 80V
    the same steppers would perk up a lot.
    Craig
    Craig
    Mar 2023
    4
    Hi, so sorry to hear. Please don't worry, our engineer will provide after-sales support for you. Please feel free to contact our engineer:
    Mike Peng
    Whatsapp: +86 158 6500 9262
    Email: [email protected]
