Innovation Weld Cut Carriage: Oscillate Weld torch TIG MIG MAG / CNC Plasma Oxyfuel Cut .
https://youtu.be/Q21p3r73cqA
No More Sweating! Innovation Magic functions Welding Cutting Carriage Trolley,
Oscillate Weld torch TIG MIG MAG / CNC Plasma Buit-in vector cut shapes!
1. Magnetic Rail base Vertical Work available, One hand carry 19kg only!
2. Effective range: 1000*1500mm Add extra Rail length $45 /meter
3. Oscillate welding system, Oscillate range speed adjustable, Digital display Screen,Run speed control, Weld Speed: 100-8000mm /min
4. Cnc plasma oxy-fuel flame cut vector shapes library.
5. Beam Track Material: Aluminum alloy extrude light and strong structural.
6. Functions: Automatic control of Steel plate Weld (TIG MIG CO2 MAG) / Cut (PLASMA OXY GAS)
7. Small Packing: Total 2*carton boxes 24kg, (Weld Carriage HS.8515809090 1*CNC carton 40*25*40 cm 10kg, 1*Rails carton 180*32*15 cm 14kg )
8. Video references:
https://youtube.com/shorts/JwXsN6jGFeI
Mark wang
www.toploong.cn
[email protected]
Shop: https://toploongcnc.en.alibaba.com
