586,500 active members*
2,486 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > HELP WITH WIRING PROXIMITY SENSORS AS HOMING AND LIMIT SENSOR
    Sep 2003
    1472
    Mach3, SmoothStepper ESS, C25 BOB, Gecko 540 driver, 2021 screenset
    Proximity Sensor: type LJ12A3-4-Z/AX. NPN NC 6-36V
    Resistor: 330 ohms 2%
    V Diode: 0.5W 4.7V
    DC Transformer 12VDC
    The C25 BOB requires a voltage 5V or less to operate normally.
    I am attempting to add proximity sensors to me homing and limits.
    My problem is that I have been unable to get agreement on the wiring for the proximity circuit.
    There are three connections on the Proximity itself. Black being the output to the Input of the BOB, Brown connecting to the +Voltage and Blue to GND. This is what I have found on the internet.
    Here is the circuit drawing that I have, it or the components must be in error because I measure only 0.6V
    When it is near metal or not. The LED cycles on and off as expected when near metal. See circuit for measurements taken at various places.
    Please let me know where I am in error.
    Hager
    Nov 2012
    1267
    Re: HELP WITH WIRING PROXIMITY SENSORS AS HOMING AND LIMIT SENSOR
    Judging by the symptoms, you have connected the Zener diode backwards.
    Sep 2003
    1472
    T hanks so much for all your help, but for now I’m giving up on Proximity Sensors. Get some projects I’ve got to get done.
    I have installed micro switches in the X, Y, and Z home.
    Again thanks. And before I attempt to go the Proxcimity route again I have full understanding of the wiring configuration I need.
    Nov 2012
    1267
    Try the proximity sensors again when you have a chance. They are really awesome devices, you will love them. :wave:
    The schematic in your first post is correct. It should work if all the components are working and wired correctly.
  1. Trouble wiring proximity sensors
    By Cbert in forum CNC Machine Related Electronics
    Last Post: 05-21-2022, 05:54 PM
  2. Need help: Z axis proximity sensors and homing setup
    By Kosh in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2016, 04:14 AM
  3. C10S wiring NPN proximity sensors
    By justinq in forum CNC4PC
    Last Post: 01-08-2016, 01:33 PM
  4. Helpful Tips For Using Inductive Proximity Sensors For Homing/Limits
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 04-13-2013, 12:30 PM
  5. proximity sensors for homing or thc?
    By Wolfesmetalfab in forum CNC Machine Related Electronics
    Last Post: 12-03-2008, 07:30 AM
