Hello,
I have been working with a Cincinnati Milacron Arrow 1000 with Acramatic 2100 control for a few months now. Machine works great and runs smooth. A few days ago while cleaning out chips, I accidentally jogged it into the Y limit switch before alignment. It through the standard fault and turned off the drives. When trying to turn it back on to move it off the switch, it faulted a few more times and then wouldn't even attempt to turn the drives on (the software also froze up and I couldn't navigate to different screens).
I decided to fully shut down the machine and manually move it off the limit switch. When turning back on, it now fails the startup diagnostics for the Bridge Board (RT), Conv. Servo, High Density I/O, Pendant/Panel (MSL), and Realtime Processor.
During the diagnostic there are popups that say:
[S_CURPOS_DSP[0]]. Value Size is Zero
Application startup timeout. The exe name is CNC.EXE
[S_CURPOS_PGM[0]]. Value Size is Zero
Application startup timeout. The exe name is RAP.EXE
What I have tried so far:
Reseated all of the cards connected to the Bridge Board
After the machine is on, the "Real Time Fail" and "Workstation Fail" LEDs are illuminated on the Bridge Board
This has happened once before a month ago when the air supply shut off while it was running. I couldn't get it to boot up again, went home for the weekend, then it started up with no issues on Monday. I have seen only two threads about similar problems, but they occurred when powering on the machine after a long period of no use. I also have around 15 manuals for the machine and the different hardware, but haven't found anything useful in them.
Just to summarize, the machine was running fine, ran into a fault, froze up, and now won't bootup properly.
If anyone has incite or has suggestions on places to look for solutions, that would be majorly appreciated.
