586,103 active members*
3,651 visitors online*
    Mar 2004
    136
    Chattering Marks
    Hello Everyone
    As per the title, and photos attached
    Chattering marks on CNC KingRich Teach lathe ??? Looking for some answers / advice or whatever
    Only very new to cnc Lathe work, so im looking for possible directions/ solutions towards preventing such chattering on the end of Bar stock.
    After some thoughts or possible explanations i can check or ......
    The steel is 40mm Dia , grade 1050 medium-carbon steel, sticking out from the 3 jaw chuck at about 160mm
    I have tried all sorts of feeds and speeds , Carbide inserts at various combinations. But still chattering marks at the first 40 mm from the end.
    any help or your thoughts would be greatly appreciated
    Jan 2013
    126
    Re: Chattering Marks
    What is your depth of cut?
    Mar 2004
    1543
    Your machine is not rigid enough for that cut. Try less DOC first, less feed. One trick that works for me is to use inserts made for AL. They actually have positive rake and less cut force. do not last as well though.
    Mar 2004
    136
    Thanks for the replies.
    Actually was the opposite case. ie i was taking too small of cut.
    Figured it out , messed around with few more feeds ands speeds doc etcAttachment 493122
    Ended up nice at 1.6mm depth of cut with 120 sfc m/min 0.16 feed
    the results like mirror finish, im sure i can push it a lot harder then this. but will do me for now.
    the only problem the conversational programing on the fagor 8055 is little light on for options so now i need to
    figure out how to transfer files into it...That way i can use fusion 360 to refine the process.
    Theres a serial port so im sure i can but i cant find any menus on the screen that show DNC or import etc
    Anyone know much about the fagor 8055tc ? in particular transfer files into it ? i have looked at the manuals i have and says nothing about importing files or gcode etc
    heres a photo of the screen ....
  1. Y Gantry Grinding/Chattering - Please View
    By Spok509 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-29-2022, 01:20 AM
  2. VMC20 X-Axis Chattering/Vibrating
    By WeTDrEaM in forum Fadal
    Last Post: 04-01-2012, 01:58 PM
  3. Trouble with chattering tool
    By 8man in forum Benchtop Machines
    Last Post: 10-22-2007, 12:58 PM
  4. HAAS (HL-4) Groove Chattering
    By san in forum Haas Lathes
    Last Post: 06-26-2007, 01:34 PM
  5. 9X20 Lathe chattering problems
    By ccm in forum MetalWork Discussion
    Last Post: 10-22-2005, 06:55 PM
