586,069 active members*
3,286 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Head stock drops down when machine is powered off
Page 1 of 2 12
Results 1 to 20 of 25
    Jul 2007
    29
    I have had the head stock drop down a few times after I power down the machine.
    If I turn off the Mach 3 contoller program, power down Windows
    then shut down the machine, the head slides down until it hits the bed or the vise.
    This screws up my Z location, therefore when I power back up I need to reset the Z home and re set my work offset.
    Do I need to shut off the controller software?
    Has anyone else had this problem? Any imput would be helpful.
    Best, Dave
    May 2007
    163
    You gota titen up the gib on the Z
    Jul 2006
    32
    I have the same problem, but its when I first power up the machine. However I resolve this by sending Z axis home, and then it stays. I'll cheek my gib. maybe thats it. Andrew
    May 2007
    163
    I think the weight of the head needs to be offset in some manner so the gibb doesn’t have to be so tight.
    Apr 2004
    22
    You have to adjust the Z axis gibb. There are instructions for this in the back of your users manual for the machine. It is a very simple process, but needs to be done after you have had the machine for a while. The issue is, once the machine "settles in" from use, it needs to be adjusted.
    Sean
    May 2007
    163
    Ya I"ve read it.
    Apr 2006
    3498
    Install counterweight, if u still get problems..
    Jun 2006
    2512
    Have I missed something here. When you turn of your machine/computer don't you lose the Z home/reference anyway. If you just shut off the machine you should not rely on the head maintaining position anyway. A few steps movement and you are screw. I think it's not good practice.
    I think when you shut down and restart you should re-reference the home positions and the workpiece anyway.
    Regards
    Phil
    Quote Originally Posted by brooklynmetal View Post
    Best, Dave
    Jul 2007
    29
    Phil,
    I understand what you are saying, I'm used to manual milling with a two axis DRO (X,Y)
    on a Bridgeport 2J and am getting aquainted with the CNC reality.
    I think TT350 and Sean's referance to the Z gib adjustment makes sense.
    It was unsettling to have the head slide down and not be able to stop it.
    I will consult the manual on this issue.
    Pleased to say I'm starting to get good results in the type of parts I'm making.
    Thanks for the response.
    Best,. Dave
    Apr 2007
    323
    im sorry if this is off topic a lil' but ,i worked in a shop one time that had a milling machine that would drop the head whenever the power went off..i think that machine had to have a axis screw brake adjusted..i cant remember it was about 4 years ago...and i have the worst memory of all man kind...still the problem was really bad.one time a guy was simply indicating a hole on a part with a $200.00 interapid indicator when the power flickered...the head was on its way down slowly till it stopped ..with his indicator between the spindle and the part...needless to say the indicator was ...not god for anything any more... the machine also had that problem when you hit the emergency stop..so..you had better have a REALLY good reason to hit the stop button..you would sit there while the machine was throwing sparks.thinking to your self."i know i need to stop it,but i cant make my self do it...."cause it would most likely kill your part and tooling ...well thats my 2 cents
    "witty comment"
    Apr 2004
    22
    I had the same problem with my Tormach about a year ago, it sounds like they all do it. I just adjusted the gibbs and the head hasn't come down since. No need for counterweights, just adjust the gibbs and everything will be fine.
    Aug 2005
    52
    My Machine is about 3 weeks old and had the same problem. After adjusting the gibbs my Z head no longer starts sinking after
    starting up or powering off.
    One thing I don't quite understand is the document states that when the power is off try to pull down
    the head manually with 40-80lbs force well my whole wieght (140lbs) was not enough to pull the head down (while the power was off)
    . But the head was still sinking down. So I adjusted the gibbs anyways at small increments like half turns and I stopped adjusting it when
    it was not sinking anymore after startup.
    Here is a video showing the sinking problem. After startup and shutdown.
    http://nagycnc.com/temp/z_axis.wmv
    James
    http://nagycnc.com
    May 2007
    163
    My head fell for the first time the other day, it was
    or first cool snap of the year about 50deg.
    When it fell it didn’t obsolete like yours it just started
    down in a smooth steady fall.
    Jul 2007
    438
    are the heads still falling on the machines with the z axis brake?
    Oct 2006
    669
    I kinda thought that's what Greg said the Z-axis brakes were installed for, on the new machines...
    May 2007
    163
    I'm going to counter the weight of the head on mine.
    I think titing the gibb to control this puts to much stress
    and wear on the Z ball screws and ways.
    All the big commercial machines are done this way.
    Jul 2006
    Might this be an unintended consequence of the Turcite surfaced ways that no reasonable amount of tightening would solve (low friction normally being a good thing).
    Apr 2006
    3498
    Before installing counterweight i will give u a few suggestion:
    1) Contact the OEM
    2)Low th IPM of the Z-axis i.e. By Tuning the Z-axis motor through the software
    3) Installed the counterweight in such a way that it always lesser then the weight of ur z-axis movable gantry.
    Apr 2006
    3498
    Sorry omit the second suggestion:-)
    Jun 2006
    2512
    I think this is the only real reason to worry about the Z-axis fall. The solution to this would appear to be a brake. If tightenng the gib (according to the manual) doen't get it then I would contact the OEM regarding a retrofit brake, or design one yourself.
    The plus side of a falling Z is you know the gib is not to tight, causing unecessary wear.
    Phil
    Quote Originally Posted by .xXACEXx. View Post
    .... the machine also had that problem when you hit the emergency stop..so..you had better have a REALLY good reason to hit the stop button..you would sit there while the machine was throwing sparks.thinking to your self."i know i need to stop it,but i cant make my self do it...."cause it would most likely kill your part and tooling ...well thats my 2 cents
Page 1 of 2 12
  1. Chuck that drops...
    By simonfilm in forum Uncategorised MetalWorking Machines
    Last Post: 01-02-2009, 03:40 AM
  2. Looking for a lathe head stock 9-13"
    By DennisCNC in forum Uncategorised MetalWorking Machines
    Last Post: 09-24-2007, 11:27 AM
  3. RFQ: NHRA Pro Stock head simi finishing
    By S V R E in forum Employment Opportunity
    Last Post: 07-23-2007, 03:12 PM
  4. True Head stock
    By frankg521 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-28-2006, 02:19 AM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
