Hi pippin,
that is correct, I have applied a load in the X axis direction, if you like 'bending the headstock sideways'. As peteeng has pointed out I'm being lazy and applying a 100N force at the corner of
the nose rather than in the middle, which mildly distorts the stress pattern, but is just so simple when running Fusion FEA.
The constraints are the two opposing edges to mimic a row of five cap screws down opposing flanges. There again not a perfect representation of reality but a reasonably
close facsimile thereof.
The advantages of using simple and repeatable settings for application of load and applying constraints is that you can run multiple FEA studies and be assured you are seeing
the results 'of that thicker flange' or 'thinner wall' or whatever it is you were experimenting with. I imagine in time I'll settle down to one model which is more realistically loaded and
constrained. At the moment 'broad brush strokes' are in order that I determine those most critical parameters and dimensions.
Craig
