586,035 active members*
3,770 visitors online*
Results 1 to 7 of 7
    Mar 2019
    58
    z axis excess error fanuc OM
    any solution??
    my battaries go away and i tying to collect all data from internet
    and now i have this error
    can u tell me how can i remove it
    Mar 2019
    58
    Re: z axis excess error fanuc OM
    error 430
    and diagnostic 772 = 1
    Mar 2019
    58
    any help??
    506 = 16666 Servo error limit Z during move
    595 = 100 z Limit of position deviation in the stop state for eadh axis 1000 mean 1 mm
    714 = 10000 Pitch error compensation interval for z axis.
    737 = 0 distance of second refrense position from the firt one Z
    510 = 4789 THE MAIN BACKUP . second reference point with G30
    this is some parameter from my machine now
    Quote Originally Posted by yurirevenge View Post
    any solution??
    Try re-set the reference point.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Mar 2019
    58
    Quote Originally Posted by cncmakers001 View Post
    how Fanuc omc
    Aug 2019
    145
    There may be two excess error alarms. One for moving and one while stopped. Which are you getting and when does it occur?
    I.E. If stopped does it occur following a move? If its moving does it occur as soon as the move starts or at the end of the move?
    Is the servo stable or is it vibrating?
    Does the machine have scales? 16666 seems high for following error.
    Mar 2019
    58
    Quote Originally Posted by oetkbyentc View Post
    i getting it when i power on machine
    not when moving
    102 2
    502 20
    506 16666
    510 4789
    520 12000
    524 100
    all above from the main parameter backup of main machine
    below parameters from net and forums :
    595 100
    702 2500
    706 -560000
    714 10000
    737 0
    745 500000
    749 -560000
    757 -443978
