586,717 active members*
3,202 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How to tell number of paths being used with a parameter.
    Currently trying to pull data from a 35i Model B using Fanuc Focas. I've looked through a bunch of parameters but can't seem to find one that specifies the number of active paths. Some machines are multipath and others are only using a single path. Is there a parameter or diagnostic that will tell me the machine condition?
    Aug 2019
    145
    Re: How to tell number of paths being used with a parameter.
    Try looking at cnc_sysinfo_ex as a start. You may need to combine data from a few different calls depending on exactly what you are looking for.
  1. Mori Seiki SL-15MC Parameter Serial number 504
    By kabdelwahid in forum Mori Seiki Machines
    Last Post: 10-18-2022, 03:57 PM
  2. Bridgeport Interact 720 4 th Axis parameter number etc
    By beemergb in forum Bridgeport Machines
    Last Post: 05-12-2022, 01:49 PM
  3. Location number under the offset parameter in 802D sl
    By Sturmer in forum SIEMENS -> GENERAL
    Last Post: 09-01-2015, 11:03 AM
  4. 0i parameter number for look-ahead feature
    By sinha_nsit in forum Fanuc
    Last Post: 03-02-2009, 04:26 PM
  5. Replies: 1
    Last Post: 08-22-2007, 06:39 PM
