586,113 active members*
3,252 visitors online*
    May 2013
    14
    Threading on Haas TL1
    I was using the IPS built in program on the Haas TL1 , it looks like it was feeding in an incorrect angle. What could be the issue? How do I fix this? TIA.
    The Visual Prog didn’t show Any A value but it was feeding in an angle much larger than 30degrees , which made the thread has a much larger angle on the back side of the cut.
    Oct 2008
    1632
    Re: Threading on Haas TL1
    Do you have a picture of the IPS screen and settings and the code it produced?
    Dec 2008
    3109
    Some controls require the total thread angle placed in the programming. Others may need the indeed angle ....
    ie. for 60° thread try setting the angle to 30° (some use 29°, to allow the tool to cut a little on the infeed side). Angle is defined as perpendicular to the thread axis (...perpendicular to Z)
    Note... some controls only allow the use of specific numbers (0, 29, 30, 60) check your manual.
    May 2013
    14
    Quote Originally Posted by rwskinner View Post
    let me try that
  1. Haas TL1 new to threading
    By tlmkr38 in forum Turning
    Last Post: 10-02-2020, 06:57 PM
  2. Haas TL1
    By widget_maker in forum Tormach Slant Lathe
    Last Post: 04-13-2019, 09:29 PM
  3. Haas TL1
    By south1 in forum Haas Lathes
    Last Post: 10-11-2013, 04:42 PM
  4. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  5. tl1 haas
    By cob in forum Haas Lathes
    Last Post: 03-25-2008, 06:39 AM
