586,108 active members*
3,084 visitors online*
Results 1 to 1 of 1
    Aug 2009
    Laser cutting Kydex
    I have a 50watt CO2 laser and looking at a project where I would need to cut Kydex. Looking around Kydex is not the best thing to cut due to the gasses that are generated.
    I am looking for some suggestions for a similar material. Would like it to have a slightly textured surface with a matte color and for it to be impact resistant like Kydex.
    Any thoughts and comments are welcome.
    Thanks in advance
    Nov 2008
    643
    Re: Laser cutting Kydex
    Just glancing at the specifications on that material it says polyvinyl chloride. You can’t cut PVC on a laser because of the chlorine gas and it messes up the machine. You might already know that. The little I do on plastic it messes up my honeycomb bed.
    I would contact a plastics distributor and ask them about laser safe materials. Problem is that for plastics the list isn’t that long.
