586,103 active members*
3,612 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma l370mw c axis issue
    Nov 2022
    18
    My lathe is no longer doing c axis contouring. The c axis will jog in manual just fine, but when running a program, it will load up to 163% and alarm out. I have ran 3-4 programs cutting a square end on a shaft milling axially. I tried again today and the c axis loads up and alarms out. It will position just fine, but when it starts the cut it’s not rotating. The alarm is 1181-20 alarm-a mcs diff over spdl-1 17ae
    Aug 2011
    419
    Re: Okuma l370mw c axis issue
    Check c axis brake
    "Imagination is more important than knowledge."
    Apr 2009
    1262
    The low pressure brake comes on during contouring. The high pressure brake is used when clamping. What typically happens is that the film of grease that is on your brake eventually wears off during contouring due to the friction. The friction is there to keep the spindle from oscillating during heavy milling since just holding it electronically will allow some oscillation. I think that if you put the film of grease back onto your brake disc, that your overload will go away. Just a thin film and not enough to sling off. It’s supposed to be there.
    Best regards,
    Experience is what you get just after you needed it.
    Mar 2009
    1982
    pay attention - a Molibden based grease should be applied on the brake.
  1. Cooling fans on l370mw
    By Cris_co in forum Okuma
    Last Post: 01-06-2023, 10:09 PM
  2. Okuma 5020 z-axis issue
    By acowan91262 in forum Okuma
    Last Post: 08-18-2021, 06:01 AM
  3. Seems Z and A axis are not running...Motor issue or Step/Dir issue?
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 08:51 PM
  4. OKUMA 4-AXIS ISSUE.
    By WESTERNTOOL in forum Okuma
    Last Post: 07-27-2010, 02:14 PM
