Hello,
I would need a tooling to make round bottom holes. Diameters varies from 24mm to 45mm. Depths from 250mm to 350mm. Is going straight to round bottom drill bit a no go? I was thinking drilling maby first with a standard drill and then have two different diameter holders one for smoller holes and one for bigger ones. With a possibility to change the head for different diameters. Would this approx. 300mm hanging length require heavymetal/carbide holder or would it be ok with normal steel holder?
How would you go about it?
