586,114 active members*
3,337 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > please, what is M100 on lathe ?
Results 1 to 7 of 7
    Jun 2015
    4154
    thank you ...
    Apr 2023
    Re: please, what is M100 on lathe ?
    The term "M100" does not have a specific or universally recognized meaning in relation to lathes. Please visit Integrated Solutions for More.https://integratedsol.co.in/lathe-and-cnc-milling/
    Aug 2011
    252
    Everywhere I've read about M100 says it's user defined M code:
    "User Defined M-Codes: M100-M199"
    Example: TORMACH, LinuxCNC
    Edit: Specific for okuma lathe I've found this:
    M-Code List Cheat Sheet – Okuma Lathes
    maybe will help you.
    Quote Originally Posted by deadlykitten View Post
    thank you ...
    What is your CNC controller brand and model name?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Apr 2009
    1262
    Sync wait command. Stops processing with no read ahead until both M100s are completed.
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    hello mr wizard please, what is the difference between m100 and P ?
    and for simple lathe, 1 turret 1 spindle, what is the difference between m100 and another buffer prohibit code ? kindly
    Jun 2015
    4154
    from manual : M100 : No look-ahead of program, main spindle waiting for synchronization
    spindle is waiting for sincronization with who? or is something else waiting for the spindle ?
    does a sync comand <> M100 ignores the spindle, so M100 is added there ?
    please, i don't understand this sync / kindly
  1. Morbidelli M100
    By Jorderic in forum CNC Machining Centers
    Last Post: 09-21-2022, 08:40 PM
  2. SCM Morbidelli M100
    By Drvoseca in forum WoodWorking Topics
    Last Post: 06-11-2022, 06:39 PM
  3. m100/101
    By starsky28 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 12-09-2016, 10:27 PM
  4. M100 and above, don't work??
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-19-2014, 06:56 PM
