586,106 active members*
2,945 visitors online*
Results 1 to 1 of 1
    Jun 2023
    CO2 laser wont turn on.
    Hello,
    I was hoping someone could help me with me with my CO2 Laser.
    Model: 460
    Serial No: BGS195238
    60W
    110V
    Laser was operating normally yesterday but did not turn on this morning. I have done the following in an attempt to resolve this issue.
    First thing I checked was the emergency stop. Once I eliminated that I used an voltage meter to check the;
    1. Power supply from the wall.
    2. Power through cord.
    3. Fuses were intact.
    4. Power across power supply socket.
    The water pump works and the laser tube is intact. I am not sure where to go from here and any help would be appreciated.
    Thank you
    Caleb
    Nov 2008
    643
    Re: CO2 laser wont turn on.
    I don’t know that machine. I assume the machine runs on but no output form the tube? Most machines have safety switches on doors and will not run if the chiller has an error. Error meaning low flow or temperature
    If you know electronics you can send a signal into the power supply, just for test. Or check the water signal into the PS. Be careful as these components are dangerous.
