586,485 active members*
2,793 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Deckel Maho DMG 635V Spindle in not locking Well, Restart when spindle start rotation
    Hi Guys
    I have a DMG 635V (Haiden Hain ITNC 530) and when spindle is locked in the position, its not locked well and it can be rotated. Also when I want to start the spindle to rotate the controller would be restarted and save the service file.
    We have changed the IGBT of the driver and not working again.
    the Error that will be stored on the service file is mentioned below but we have checked the wiring of the Spindle motor there is no evidence that wiring is not ok. Also I have checked the cooling section of the spindle for leakage, and there was no leakage over there as well.
    ERR: N228 C3B0 Motor S does not run under max. current 21.01.1980 22:07:32
    ERR: 21.01.1980 22:07:32
    ERR: Module : Q:/CommonTNC/sources/regel/dsperror.cpp 21.01.1980 22:07:32
    ERR: Line : 330 21.01.1980 22:07:32
    ERR: EIP : bin\regel.elf:CODE32:0X00038B2C 21.01.1980 22:07:32
    ERR: Process: REGEL 21.01.1980 22:07:32
    ERR: Thread : DSPCLIENT 21.01.1980 22:07:32
    ERR: errno : 2 21.01.1980 22:07:32
    ERR: REF:-4258322 -2821666 -1693292 0 0 0 0 0 0 0 0 0 0 0 21.01.1980 22:07:32
    ERR: ACT:448944 -220029 1639978 0 0 0 0 0 0 0 0 0 0 0 21.01.1980 22:07:32
    ERR: Call Stack: 21.01.1980 22:07:32
    ERR: bin\regel.elf:CODE32:0X000BD078 21.01.1980 22:07:32
    ERR: bin\regel.elf:CODE32:0X00038B2C 21.01.1980 22:07:32
    ERR: bin\regel.elf:CODE32:0X00038F89 21.01.1980 22:07:32
    ERR: bin\regel.elf:CODE32:0X00027F63 21.01.1980 22:07:32
    ERR: bin\regel.elf:CODE32:0X000281E1 21.01.1980 22:07:32
    ERR: bin\regel.elf:CODE32:0X0002BF53 21.01.1980 22:07:32
    ERR: bin\regel.elf:CODE32:0X00103131 21.01.1980 22:07:32
    ERR: bin\regel.elf:CODE32:0X0010B8E9 21.01.1980 22:07:32
    Please help me the machine is not running for an almost 3 months.
    Sep 2009
    99
    Re: Deckel Maho DMG 635V Spindle in not locking Well, Restart when spindle start rota
    Hi is your machine with Heidenhain drives or Siemens drives?
    I suggest changing your spindle drive and seeing if it works
  1. deckel maho DMG 635V
    By daliborb in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-27-2018, 08:04 PM
  2. anyone own or operate a Deckel Maho DMG DMF 250 Linear vmc
    By powerstream in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-24-2015, 02:09 PM
  3. DMG Deckel Maho Post
    By aldepoalo in forum BobCad-Cam
    Last Post: 03-24-2014, 03:05 PM
  4. DMG Deckel Maho Vertical Center DMC 1035V
    By CNCCS in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-12-2008, 05:58 AM
  5. VERTICAL DMG DECKEL MAHO
    By CNCCS in forum Vertical Mill, Lathe Project Log
    Last Post: 04-17-2008, 09:24 PM
