Hi everyone, I'm having some issues with my endmill corners chipping. I suspect it's during boring operations, just because it sounds nasty when the bit ramps into the workpiece. Everything else, like 2d Contour, adaptive all spit out steady chip streams and sound healthy.
I have a hobby Langmuir MR1 cnc, and I was creating some holes in 6061 Aluminum with a new 3 flute ZRN endmill (6mm). And after that 1 piece I machined, the corners of the flutes were all chipped. This happened on other end mills as well, so I'm not sure if it's because of my end mill selection (3 flute, instead of say a 1 flute), or if it's my speeds and feeds.
The end mill is a metric 6mm (just under 1/4") 3 flute, the hole I was boring was .350" (~8.9mm). On Fusion360, I did a 2 degree bore, at 8000 RPM, 15 IPM feedrate, which is around 0.000625" chipload, with flood coolant. Even at such a light chipload, it still sounds pretty nasty. Like the bits was grinding on rocks.
I'm suspecting maybe the 2D bore operation is not meant for drilling holes, and is only meant for getting to the final ID starting from a slightly smaller ID? I figured it would be fine, since if I ran a 2D adaptive, it would also do a circular ramp into the workpiece. Could anyone let me know what I'm doing wrong here? I am still learning as I go Thank you!
