586,075 active members*
4,240 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > U10L Floppy Read/Write Problem
Results 1 to 16 of 16
    Jul 2023
    7
    Good day,
    We purchased an old Okuma OSP-U10L Lathe two years ago and we've been having floppy issues the whole time.
    Initially when we first tried copying files over to a floppy everything started out fine but soon after we started seeing an error:
    "330 floppy disk read/write ERROR 40202046"
    After the error, the floppy was no longer usable unless we reformatted thus losing all our saved info.
    We swapped the floppy drive, no fix. Changed the ribbon cable, nothing. We now have a Nalbantov N-Drive emulator which worked briefly until the same errors started.
    A company that was here to fix our Mill said that it sound's like a voltage thing but was unable to take a look because they weren't allowed unless we started a new ticket.
    Does anyone have any ideas as to how we can fix this problem? Is it a voltage thing?
    We have limited usable disk space currently and I'm constantly having to delete old programs and reprogram new ones every time we need something new.
    Any help is greatly appreciated
    DT
    Aug 2009
    1573
    Re: U10L Floppy Read/Write Problem
    ...hook up to your RS232 Com Port to a PC with example below.
    https://www.usconverters.com/wireless-serial-adapters
    and a null modem Cable
    https://www.showmecables.com/db9-fem...-_AOV&keyword=
    Jul 2023
    7
    So this device will enable me to save files on a PC and transfer them over to the U10L? Do I need two? One for the Lathe, one for the PC? Not sure how this all works.
    Aug 2009
    1573
    Quote Originally Posted by BEL_DT View Post
    So this device will enable me to save files on a PC and transfer them over to the U10L?.
    Yes, if you have RS232 port on the CNC.... DB25 port plug most likely you have. Maybe something less complex would work for ya...like USB to Serial Adapter and a Null Modem Cable is the way to go. That would be the minimal hardware you need PC to CNC Transfer/Receiving files.
    https://tripplite.eaton.com/keyspan-...dapter~USA19HS
    Jul 2023
    7
    Quote Originally Posted by machinehop5 View Post
    So here's the thing. Not the best at G-Coding (working on it though). I program on the machine itself using IGF because it's so easy. When done, covert it to a .MIN file which is the g-code it needs to run. Transferring the files back and forth from PC to CNC I don't have a lot of confidence in working because the CNC is so old (1990s-ish model I think). If I go this route, what software do you recommend I use to communicate between the two? I am somewhat tech savvy but when it comes to this I don't feel so confident on what to do.
    I cracked the control panel back and I didn't see any RS232 or a DB25 port initially. There is another panel within but it'll take some work to pull it off and have a look. I scoured the internet looking for an electrical drawing but haven't found one yet. I'm not totally sure what advice you giving will work at all.
    DT
    Jun 2015
    4154
    hy kurmay can assist you to setup comunication
    also, you could use a remote, last edition igf, so easy, and get things done
    so, in the end, you may get packed up pretty well / kindly
    Aug 2009
    1573
    DT
    ...IF.you have a Comm Port (DB9 or DB25 type) it would be somewhere easy to access for connection.
    Mar 2009
    1982
    Never seen Okuma machinetool without DB25. Post a pictures here, I will point you where to look.
    The software is good whatever you choose for serial communication, for instance very popular tool "Hercules".
    I would not advice to use "null modem cable". Take full serial cable better, it's easier to set communication working with hardware handshake.
    Jul 2023
    7
    Quote Originally Posted by Algirdas View Post
    See pics
    Attached Thumbnails Attached Thumbnails IMG_0927.jpg   IMG_0935.jpg   IMG_0936.jpg   IMG_0939.jpg
    Mar 2009
    1982
    now I undersand you are looking at the wrong place. Take general photos please. Serial interface as usual is accessible without disassambling.
    Okuma U10L
    start at the 3:05.
    The guy opens a cover marked big "3". There you can see DB25
    Jul 2023
    7
    Okuma U10L
    start at the 3:05.
    We don't have that "3" cover or anything like it. See pics. Nothing on top/bottom. The cover in the third pic leads to nothing. Ignore the dirty grease.
    Mar 2009
    1982
    take pictures of main control cabinet, please.
    Jul 2023
    7
    Here are some more.
    Apr 2006
    822
    Generally the DB25 pin port will be on the outside of the electrical cabinet. Have a look on the outside, maybe near the main switch?
    Jul 2023
    7
    Took some more pictures of the back panel away from the controls. Forgive the mess. Looking at the floor, there is a DB25 female that runs all along the outside and around to the Grey box found on the left.
    Aug 2009
    1573
    ...Photo #3 above you posted is the DB25 RS232 most likely and should be mounted to the Cabinet so, it is accessible from outside the Cabinet. Make an adapter Plate if, needed.
  1. Replies: 13
    Last Post: 04-11-2022, 07:43 PM
  2. Replies: 3
    Last Post: 01-10-2021, 01:41 PM
  3. Floppy read
    By grego251 in forum Okuma
    Last Post: 09-19-2016, 08:35 PM
  4. Read Write Protection
    By scurr in forum SIEMENS -> GENERAL
    Last Post: 06-02-2016, 10:52 AM
  5. Read Write-file
    By CNC-Span in forum SIEMENS -> GENERAL
    Last Post: 03-11-2011, 02:22 PM
