Hi
Can anyone help me with an installation of a 4th axis on robodrill t14ia please. I have physically installed the drive and motor as per the manual which was quite straight forward and then it instructs to use the Add. Axis Parameter to install it but on mine it is greyed out and I can not use it. Is there something I need to do first to enable this or do I need to manually install it. The manual makes it look easy using this option. Thanks for your time
Bernie
