586,366 active members*
3,421 visitors online*
Results 1 to 9 of 9
    Jul 2023
    MOUSE POINTER SIZE
    I have been using Partmaster Cad for quite a while now. I have a large 24" flat monitor which makes for a nice big viewing area of any drawing that make.
    BUT...
    The mouse pointer little box is kinda hard to see for an old guy like me. Is there a way to increase the size of it. I am still using Windows 7 which works fine, so if it isn't broke don't fix it is my theory. I can't be the only one with this issue but I tried to find a way to make it larger but I am stumped.
    Thanks;
    Jack
    Feb 2007
    414
    Re: MOUSE POINTER SIZE
    Hello Jack,
    We use the standard windows mouse size.
    You can changes this in the Windows settings
    ATb
    Andre
    Apr 2018
    132
    I don't have a Windows 7 machine to experiment with, but often pointer size is considered an "accessibility" function. Various sites have pages discussing Windows 7 accessibility features, but this one has a PDF that seems useful, and can easily be "saved" to your system if you choose to do so:
    https://www.leegov.com/ada/Documents...s7Features.pdf
    Nov 2012
    1267
    Go to Control panel - Mouse - Pointers - Scheme. Select one of the "Large" or "Extra large" schemes and click Apply.
    Jul 2023
    I did that and YES the pointer got a lot bigger. While I was pointing at the tool buttons it was much larger, BUT as soon as I moved to the drawing area it changes to the little small square, in my case about an 1/8" square. I have a very large monitor and I am using the highest resolution but maybe that is my problem. Maybe I just need new glasses but the VA says I can't get a new pair until the end of the year.
    Jack
    Dec 2008
    3111
    Quote Originally Posted by Jack7709 View Post
    Jack
    What about changing the screen resolution...
    Changing it down would make everything seem larger, including the cursor.
    Jun 2015
    4154
    Hi resolution is not for daily use, and it will damage your eyes. Long term trigers damage beyond repair
    Decrease resolution, adjust toolbars to only necesary, and increase distance from monitor, at least 3..4 diagonals
    Pause 10 5 or at least 3 minutes each hour, and look in the distance, as eyes will rest if what they see is not in near focus.
    Your request for bigger pointer may be an early sign of something
    Dec 2008
    3111
    Quote Originally Posted by deadlykitten View Post
    Too late for us older guys, only solution is stronger glasses. Or make the on-screen info larger, including the cursor.
    Get real Kitty.... See earlier response
    Jul 2023
    I did take the resolution down one notch and that seemed to help quite a bit. Problem solved, and I only need glasses to drive I can still see very good up close.
    Thanks for all of the suggestions
    Jack
  1. HOW DO I ADJUST MY MOUSE POINTER ?
    By keen in forum Tormach Personal CNC Mill
    Last Post: 07-28-2016, 03:44 AM
  2. problem with mouse pointer color
    By dlaery in forum BobCad-Cam
    Last Post: 04-14-2015, 02:41 PM
  3. Pointer color
    Last Post: 01-08-2014, 05:18 PM
  4. Pointer to follow tool path.
    By Kiwi in forum BobCad-Cam
    Last Post: 07-28-2006, 04:03 AM
  5. Zero pointer tool
    By Tompie in forum DIY CNC Router Table Machines
    Last Post: 08-29-2005, 08:55 AM
