586,105 active members*
3,324 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics MM18 programs issue
    May 2022
    Hi there hope you are fine!
    In the factory we have two Milltronics MM18 mill, the first with 7200 control and the other with 8200 control. We build automatic machines so we have a lot of standard programs so we need to use the same program to both machines to give a standarized files to share btw the machines.
    We reach up to the program O9999 so we introduce the program J0001, the file with J char are readed fine with the 8200 control but not with the 7200 control. What can be the reason and/or the solution?
    Can check the attached file to see the machine screen, the files are copied with USB memory
    I appreciate so much the help u can provide, regards!
    Jul 2010
    548
    Re: Milltronics MM18 programs issue
    Hi, The pics of the control helps. The 8200 is actually a 8200B control. that is a different animal. try renaming the the J0001 to O9999 and try it.
    sportybob
  1. Milltronics Centurion 6 SBC Issue with Display
    By HuxRacing in forum Milltronics
    Last Post: 03-17-2021, 11:20 PM
  2. Milltronics VM15 ATC issue
    By ajshaww in forum Milltronics
    Last Post: 04-22-2019, 04:59 PM
  3. Replies: 10
    Last Post: 01-24-2017, 03:41 AM
  4. How can I make programs from a Fanuc 20 control run on a Milltronics MB-20
    By hawkeyemfg in forum Centroid CNC Control Products
    Last Post: 01-01-2017, 09:23 PM
  5. mm18 air leak
    By markjb in forum Milltronics
    Last Post: 05-31-2012, 12:54 AM
