586,119 active members*
3,367 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Z profile / slot changes tool dimeter?
Results 1 to 8 of 8
    Oct 2009
    230
    why does it change my tool diameter on a second Z profile?
    i have only one tool described
    took me a minute to isolate the issue
    shizuoka an-s knee mill=kflop/kanalog running nema 34 dc brushed servos
    cincinnati sabre 750=kflop/kanalog building now with ac brushless servos
    Oct 2009
    230
    Re: Z profile / slot changes tool dimeter?
    view of the 2 profiles up top
    Oct 2009
    230
    plus mirror does not mirror
    even if i set repeat to none....
    Feb 2007
    414
    Hello,
    The tool size isn't changing.
    With the Tool view set to Envelope, this is showing the effective diameter at the given depth.
    Regards
    Andre
    Feb 2007
    414
    Hello
    Yes, there is an issue with Mirror on Z profiles.
    You will need to use Rotate 180
    Regards
    Andre
    Oct 2009
    230
    both have the same depth and placement
    Oct 2009
    230
    i see
    why is the depth different with the same dimensions?
    Oct 2009
    230
    ok i got it
    my profiles start at different depth!
    thanks for talking me through it. lo
  1. Replies: 15
    Last Post: 11-29-2022, 05:13 PM
  2. What's the T-slot profile on the Z axis used here?
    By GlynnW in forum T-Slot CNC building
    Last Post: 10-17-2022, 03:01 PM
  3. V26 and T-Slot Tool Path
    By Analias in forum BobCad-Cam
    Last Post: 10-19-2014, 10:34 PM
  4. Replies: 0
    Last Post: 03-21-2013, 09:19 PM
  5. T slot tool post with drill bit tool holder
    By brucesu1 in forum CNC Tooling
    Last Post: 06-09-2008, 11:04 AM
