586,597 active members*
3,411 visitors online*
IndustryArena Forum > CNC Electronics > Rutex Products > trouble with configure and testing R990H servo drive
Results 1 to 2 of 2
    Jan 2007
    93
    Unhappy trouble with configure and testing R990H servo drive
    In the document i insert pictures with messages i get when i use RT990H (DOS) and Rutex Tuner(Windows)
    I am not useing rutex motheboard but i wire it direct to parallel port .
    What to do?
    Attached Files Attached Files
    Aug 2004
    2849
    So, there must be a signal (wire) that is used to indicate that a Rutex driver is connected.....or is the software interrogating the driver and it's responding , but your communication back to the computer is mis-wired? Look at the Rutex documentation....look for a driver sense line...
  1. Trouble with Yaskawa Drive & Servo
    By curtisturner in forum Servo Motors / Drives
    Last Post: 04-28-2011, 06:57 AM
  2. Testing Drive Boards
    By bob a job in forum CNC Machine Related Electronics
    Last Post: 11-22-2007, 11:07 PM
  3. Replies: 2
    Last Post: 04-10-2007, 03:45 AM
  4. Testing for drive enable?
    By murphy625 in forum CamSoft Products
    Last Post: 04-06-2005, 10:04 PM
  5. R990h
    By dpaulson in forum Rutex Products
    Last Post: 02-22-2005, 04:35 PM
