586,103 active members*
3,854 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > SpectraLight and Mach3: XML File Share
    Jan 2012
    13
    Post SpectraLight and Mach3: XML File Share
    Has anyone been using the parallel cable conversion using the original controller, I believe controller 0200. It only has two axis, x and z according to the manual?
    It you can share your XML file to figure things out with the pins out, I will appreciate it.
    If there's anything else I need to do beside the cable to make the motors move, please share. Thank you.
    -Ernesto
    Mar 2016
    325
    Re: SpectraLight and Mach3: XML File Share
    U can find info (even on this forum) what U need to change on the ghenuine main board to make it work with M3. As far as i remember it requires cutting and resoldiering 1 or 2 pcb tracks.
    Jan 2012
    13
    I've been looking for this information about cutting and desoldering the tracks. I started to experiment with Mach3. So far I can enable the controller to energize the two motors and I can activate the spindle when hitting the spindle button. But no movement on the motors. I rechecked that parallel crossover cable but nothing there. If anyone has any insight, let me know. I even went to increase the step pulse to 15us and nothing. I will try to enable the Y axis just in case the controller board just has two axis.
    Mar 2016
    325
    I guess there can be an answer:
    https://www.cnczone.com/forums/contr...ller-card.html
    But not every link is working now. Maybe try to contact shannon_haworth for some info.
  1. xml file mach3
    By DesHow in forum Mach Mill
    Last Post: 08-14-2017, 04:19 PM
  2. would like to see g540 mach3 xml file
    By johnyac in forum X3/SX3/G0619/G0463
    Last Post: 03-20-2014, 07:18 AM
  3. G540 Mach3 XML File
    By CoAMarcus in forum Gecko Drives
    Last Post: 11-08-2008, 06:38 AM
  4. Mach3 xml file for use with a laser
    By dmauch in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-12-2008, 03:50 PM
  5. Mach3 xml file
    By Ed Williams in forum Mach Mill
    Last Post: 04-08-2006, 01:50 AM
