Hi folks,
I have this issue: I am milling with a 2mm flat endmill into silver. I set the Z feed to 20. But Madcam plunges the tool with a G00 move into the material, sometimes causing a tool break. This is what the code looks like, and the problem happens at line 9. I can manually add a G01 in between, but why does Madcan not honor the Z feed speed?
I am thankful for you input.
Maarten
G00 G49 G40.1 G17 G80 G50 G90 G64
G21
(C3b plaat)
(vinger 2)
M6 T1
M03 S6000
G01Z5.000
G00X-2.770Y-0.818
Z4.060
Z-1.772
G01Z-2.472 F20
