586,114 active members*
3,310 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Error 450: time out while waiting for arm at 45
    Been struggling trying to find a solve the tool change arm is locked in line with the spindle and will not move. Looked in our owners manual for answers but turns out we are missing half of the book so wasn’t able to find anything. Any help would be greatly appreciated thank you.
    Re: Error 450: time out while waiting for arm at 45
    Quote Originally Posted by Hegdahl174 View Post
    What is the machine model name?
    And what is the CNC controller model?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jul 2010
    548
    The control is waiting for a prox switch input to the control. I assume the arm is stuck at 45 degrees. Use a 12mm socket on top of the motor to back off the arm to a straight position. watch for the red LED lights on the prox switches under the plastic cover on the tool changer.
    Might have a bad prox switch or possible the rectifier on the arm motor is not pulling the motor brake off
    Sportybob
  1. Error 450 on centurion 6. Need code for builder.
    By hernault in forum Milltronics
    Last Post: 12-09-2015, 06:18 PM
  2. Bridgeport TC-3 tool-arm time out
    By forhire in forum Bridgeport / Hardinge Mills
    Last Post: 06-05-2013, 02:42 PM
  3. Error 449 instead of Error 450 during bootup
    By genebaq in forum Milltronics
    Last Post: 10-25-2012, 06:15 AM
  4. Partner 1G Centurion V 450 error
    By BilletCharlie in forum Milltronics
    Last Post: 07-06-2012, 02:34 AM
  5. Milltronics Centurion 5 450 error Help!
    By Footie11 in forum Milltronics
    Last Post: 11-15-2010, 10:04 PM
