586,080 active members*
3,871 visitors online*
    Sep 2011
    29
    Power feed XL possible?
    I just picked up a round column mill and I want to have a power feed +, is something like this available, like an MCU and code, basically a stepper with driver moving my X and Y, plugged into an MCU in the back of an MPG pendant.
    Basically a computer controlled power feed, you can set axis and move it with the jog encoder or you can set a direction, speed, distance on a small keypad, I could probably build the pendant but I'm not a coder.
    I don't want to run programs as such, something much more lightweight, small footprint, I already have a CNC.
    Is something like this available?
    If it is a thing, bonus points for it outputting coordinates to a seperate (larger) DRO screen and/or being able to support encoder inputs so you could have open/closed position feedback loops?
    Cheers
    Richard
    Sep 2011
    29
    Re: Power feed XL possible?
    The only other thing I would add is a setting for single cuts that would need XY moves, angles and arcs.
  1. Feed power
    By enzo33 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 07-22-2020, 03:49 PM
  2. Power Feed
    By kolias in forum Spindles / VFD
    Last Post: 11-21-2013, 03:34 PM
  3. Power feed
    By n2xd in forum Shopmaster/Shoptask
    Last Post: 11-09-2009, 01:50 PM
  4. Rong Fu RF 45 with power down feed
    By lobecnc in forum Benchtop Machines
    Last Post: 03-10-2008, 11:00 PM
  5. power feed?
    By GalaticDan in forum Mini Lathe
    Last Post: 11-30-2006, 06:01 PM
