586,094 active members*
3,912 visitors online*
    BL-USBMach v2.0 D2103 communicate error
    Hello everyone,
    I bought BL-USBMach v2.0 D2103 and I am having problems with communication and reset button. The problem is:
    When USBMach is not connected to pc, in the right side of Reset button I see "Emergency Mode Active". When I press reset button in mach3 software it is working and I can see axis values that change when I press arrows in keyboard.
    When I select BL-USBMach v2.2 plugin and connect my USBMach to pc, it says "USBMach connected". The problem is that I can't reset. When I press Reset button in mach3, it says "USBMach communicate error".
    I tried to toggle "Active Low" in Estop but result is same. When I try to save after doing "Active Low" option true, mach3 program freezes and crashes.
    I am running system in windows 10, could be the problem? Or maybe wrong dll plugin?
    I can't see any change in device manager when I plug the board. Could be the problem?
    No motors or anything is connected to mach3 board, I am not powering it seperately, only Usb is connected to PC.
    Thanks for your helps...
    Nov 2023
    Re: BL-USBMach v2.0 D2103 communicate error
    Hi
    Did you sorted out ?
    Lightbulb Re: BL-USBMach v2.0 D2103 communicate error
    I used BL-UsbMach-V32.dll and BL-UsbMach-V325.dll in Windows7
    Both works and there is NOT any more communication error. Have a nice day.
    Apr 2022
    135
    I would stay away from this boards…
    But since you already got it.
    1. They work right with Windows XP one can make it work with Windows7. ( I think it design to work with 32 bit system)
    2. Try to use Mach3 that is not Pirated or at list known working version.
    3. Use ports and pins as it states in the manual, specifically for e-stop, inputs and outputs.
    4. Check the address of the port .
  1. BL-UsbMach-V2.1 issue
    By Renda in forum Mach Software (ArtSoft software)
    Last Post: 12-03-2022, 10:55 PM
  2. BL-USBMACH-WS-3.25 Output not working
    By cusna in forum Machines running Mach Software
    Last Post: 12-02-2022, 05:28 PM
  3. UsbMach communication error
    By galshak in forum Chinese Machines
    Last Post: 05-07-2022, 04:59 PM
  4. Does BL USBMach V2.0 support slave axis?
    By ccysio in forum Mach Software (ArtSoft software)
    Last Post: 05-12-2020, 09:56 AM
  5. Need Help for PWM Spindle Configiguration for BL-USBMACH BB
    By shadeyinka in forum Machines running Mach Software
    Last Post: 03-13-2020, 05:35 PM
