586,089 active members*
3,845 visitors online*
Results 1 to 1 of 1
    Sep 2012
    Enroute Array
    Is there such a thing? or a copy multiples at a certain x or y axis?
    Thanks.
    JJ
    Oct 2022
    9
    Re: Enroute Array
    Is the multicopy tool what you are looking for?
    https://youtu.be/jUbVMTvpclw
    Re: Enroute Array
    Are you looking for the make multiple copies menu?
    Click on the "Draw" pull down menu then click "Multiple copies..." Or there is a shortcut to that on the "Contour Edit" Toolbar (usually on the lower left side of the screen.)
    This lets you make a grid array copy of a selected item or items, where you can specify the number in the X and Y directions and the spacing of those copies in each direction.
