586,116 active members*
3,440 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Read turret encoder value
    Aug 2011
    419
    Hi
    Are there any variables for read turret encoder value (actual position) on okuma lathes?
    I need to add a control (check) for turret position is true.
    "Imagination is more important than knowledge."
    Re: Read turret encoder value
    Quote Originally Posted by kurmay View Post
    Hi
    What kind of turret on your lathe
    Normally the turret will feedback its position to the CNC controller.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Aug 2011
    419
    Machine has servo turret (NC turret)
  1. How to read magnetic incremental encoder specs - yc-52010
    By jboyd79 in forum Servo Motors / Drives
    Last Post: 01-12-2018, 05:30 PM
  2. Mitsubishi J3 A Encoder read issue
    By Ya-Nvr-No in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-29-2013, 11:25 PM
  3. Linear Encoder Read Heads.
    By HackerMechTech in forum Knee Vertical Mills
    Last Post: 05-08-2009, 09:14 PM
  4. Linear Encoder Read Heads.
    Last Post: 05-05-2009, 06:02 PM
  5. Encoder and read out
    By DaveDoesIT in forum CNC Machine Related Electronics
    Last Post: 10-29-2008, 06:26 PM
