586,108 active members*
2,941 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Galil DMC Controller with Baldor TSD Servo Drive --- Wiring Help
    Apr 2010
    18
    I am building my own XYZ Plasma Cutting rig, and I am stuck... for some time now... trying to get my Galil 2183 controller wired correctly with my Baldor TSD-050-05-2-U Servo Drives…and from the Galil 2183 controller to the Baldor MK-2250 DC Servo Motors....It's the pinout terms used on the Galil vs Baldor components . I need help with the +-10V motor control signal from the Galil to the Baldor Drive and not sure how to wire the pins 1,2
    I've attached a pic of the current layout I have configured..... it doesn't work. the motor does not accept simple move commands...
    thanks,
    Brian
    Attachment 495378
    Dec 2013
    5717
    Re: Galil DMC Controller with Baldor TSD Servo Drive --- Wiring Help
    You may have a problem there. It looks like the +/-10V input needs to be a differential input, the Galil only outputs a single ended +/- 10V command signal, with a differential signal as a factory installed option.
    Look in the Baldor documentation and see of the drive will accept a single ended signal and how to configure it.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2010
    18
    I figured this out with help from other sites. Here's my approach for the wiring that is working so far.
    Here's the Limit Switch Wiring
    Attachment 495960
    Apr 2010
    18
    Thumbs up Re: Galil DMC Controller with Baldor TSD Servo Drive --- Wiring Help
    UPDATE !!!
    I replaced the Baldor TSD Drives with something *newer*! I am going with Advanced Motion Controls 12A8M servo drives. Here's the updated schematic. I have Galil GDK tuning software working with this configuration. Tuning the drive POTS are a pain, but better on the AMC, rather than the very dated Baldor TSD approach, POTS are not an exact science I must say ... a little rough science...
  1. Replies: 1
    Last Post: 10-09-2019, 07:09 PM
  2. Galil DMC-1050 controller retrofit
    By Jmhx2 in forum Controller & Computer Solutions
    Last Post: 09-14-2014, 04:59 AM
  3. Galil DMC 2240 CNC Controller & Acessories
    By Tim Whitford in forum Australia, New Zealand Club House
    Last Post: 06-15-2012, 02:10 AM
  4. GALIL DMC 2182 & Vexta 5 Phase Wiring
    By CNC1970 in forum CamSoft Products
    Last Post: 11-09-2007, 01:05 AM
