586,666 active members*
4,398 visitors online*
Results 1 to 2 of 2
    Nov 2013
    103
    Logitech F710 Game Controller Issue
    Greetings all,
    I just V carved a very simple 3" x 5" graphic with 4 letters enclosed by a rectangle. The result was distorted thickness of the V carve characters and rectangle lines. The z axis appears to have not descended to the full depth of the characters and rectangle lines.
    The cnc router axis also started to drift when I used the Logitech 710 game pad controller. I think this drift affected the z axis during the V carve operation. Therefore, I removed the batteries from the game pad controller and used the KmotionCNC screen to set the xyz zero positions. The resulting V carve was not distorted.
    Is there an alternate/better game pad controller or a wired or IR cnc control pendant with a dial available for the manual control of the machine?
    See the attached example of a handheld controller with dial.
    Please advise,
    Ted
    May 2006
    4047
    Re: Logitech F710 Game Controller Issue
    Hi Ted,
    I think there are some settings in Windows for reducing drift with gamepads/joysticks.
    But yes an MPG such as that directly connected to KFLOP would be much better and have guaranteed instantaneous response without any Windows/PC/USB delays. See our wiki here.
    TK
    http://dynomotion.com
  1. Logitech Cordless controller Rumblepad
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 07-14-2009, 02:35 AM
  2. New help Pendant vs Game Controller Hack for Taig
    By gunlocators in forum Taig Mills / Lathes
    Last Post: 10-31-2008, 07:40 PM
  3. Setting up a Logitech controller with Key Grabber
    By Stuff-Builder in forum Mach Software (ArtSoft software)
    Last Post: 03-01-2006, 12:26 AM
  4. Game pad controller
    By plateroomred in forum CamSoft Products
    Last Post: 06-17-2005, 07:23 PM
  5. CNC controller in arcade game cabinet.
    By ynneb in forum Community Club House
    Last Post: 04-23-2004, 12:52 AM
