586,077 active members*
3,688 visitors online*
Results 1 to 8 of 8
    Nov 2013
    103
    Upgrade issue
    Guys,
    Followed the upgrade instructions:
    Backed up the version 433 directory.
    Downloaded and installed the 510 version to the default directory.
    Copied all files in the 433 Data directory and pasted into the 510 Data directory.
    Ran the new KMotion.exe 510 application.
    The following message appears:
    Error Status Record Size Mismatch.
    Clicked Yes.
    Read Failed - Auto Disconnect.
    Clicked OK.
    Stuck.
    Please advise,
    Ted
    Jun 2013
    1041
    Re: Upgrade issue
    Did you open kmotion.exe go to the configuration and flash screen and flash the new version into k-flop?
    Sent from my E6910 using Tapatalk
    Nov 2013
    103
    Re: Upgrade issue
    bhurts,
    Can't proceed. KMotion disconnected.
    Launch KMotion 433.
    Title bar text: KMotion - Connected.
    Click USB Locations tab.
    Text: Board 0 @ 0x12.
    Launch version 510
    Error Status Record Size Mismatch message appears
    Disable future status updates?
    Click Yes.
    Title bar just reads KMotion.
    Tab text is USB/IP Locations.
    Click this tab.
    First line text: KFLOP 0x12.
    Second line test: Manual IP.
    Jun 2013
    1041
    Re: Upgrade issue
    Have you updated the driver for the new version? I believe you would go to windows devices and find k-flop under usb. Select update driver and select the new one from kmotion 510. Not sure if that will help but that is what I would try next. If you don't get any better replies in the next day or so I will try upgrading one of my machines to 510 and let you know how it goes.
    Nov 2013
    103
    Re: Upgrade issue
    After firmware flash and power cycle the console still returns version 4.33.
    Not 510.
    Frustrating.
    May 2006
    4045
    Re: Upgrade issue
    Hi Ted,
    Launch KMotion 433.
    Launch version 510
    Click Yes.
    After this you should get a Disconnect message. Click OK. Then Flash New Version. Then re-boot KFLOP and restart KMotion.
    HTH
    TK
    http://dynomotion.com
    Nov 2013
    103
    Re: Upgrade issue
    Guys,
    Powered everything down.
    Ate a quick supper.
    powered everything up.
    KMothin - Connected- KFLOP 0x12
    Send version command with console.
    Returns: KFLOP Version 5.1.0 with time and date
    KFLOP 5.1.0
    Ready
    Praise God.
    Thanks for the effort.
    Ted
    Dec 2023
    Re: Upgrade issue
    The error message suggests a mismatch between the data format expected by version 510 and the existing data from version 433. Check the KMotion documentation or online resources for information on data format changes between versions.
  1. Router upgrade, build versus buy older machine and upgrade.
    By Rickv100 in forum Uncategorised WoodWorking Machines
    Last Post: 01-04-2023, 02:38 PM
  2. WARNING - PathPilot Upgrade Issue - Sudden Spindle Engagement
    By MetalDawg in forum Tormach Personal CNC Mill
    Last Post: 07-09-2016, 10:24 PM
  3. Replies: 1
    Last Post: 01-08-2016, 06:58 AM
  4. Replies: 5
    Last Post: 04-15-2015, 05:10 PM
  5. Resonance issue & Upgrade
    By justCNCit in forum Xylotex
    Last Post: 09-28-2008, 06:02 AM
