586,401 active members*
2,862 visitors online*
Results 1 to 1 of 1
    Job Statistics
    I can't seem to get my job statistics to work in Enroute 6.1
    does any body now if they removed it in version 6.1.0.20
    Re: Job Statistics
    I use Enroute 6.1.0.15 and the job statistics still works for me. I am running on a 64-bit Windows 7 PC. If I click on the "Machining" pull down menu, then click "statistics" Enroute causes a Windows Internet Explorer window to open and displays the file "C:\EnRoute6_1\job_stats.xml"
    You could try opening that xml file manually to see if Enroute is updating the statistics but failing to automatically open the window to view it.
