587,034 active members*
3,181 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > How to remove Helix milling?
    Jul 2023
    6
    Question How to remove Helix milling?
    Trying to mill some pockets in aluminum. Instead of doing a helix pattern ramp in (which is great), it's also doing a helix milling pattern around the entire part.
    Doing 12 pockets like this is going to take 9.5 hours to complete. Seems a little off.
    How do I go about doing standard milling?
    On the swallower pocket section, it'll do a standard milling, however when it goes to cut the deeper pocket, it starts the helical milling.
    Dec 2013
    5714
    Re: How to remove Helix milling?
    Assuming you are using Fusion 360, uncheck Ramp on the Linking tab for that operation
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2023
    6
    Thank you for the response. Yes, I am using Fusion360. However, I am not seeing an option to "uncheck" the ramping option. Am I missing something?
    Jul 2023
    6
    Figured it out.
    For those that are interested, I went from 2d adaptive clearing to 2d contour, selected pocket and chose the face. That took care of trying to helix mill the entire pocket.
    Problem solved.
