I recently bought an older D&M 4 CNC enclosed "trainer" with a Sherline Mill off eBay. It arrived with a different drive motor than pictured. The one in the picture was a larger diameter black one like you see on the Sherline web page.
The motor I received was a smaller diameter silver coloured marked 40v DC (however it looks like a number was scraped off to the left of the 40 - perhaps a 2 or a 4??, or maybe just something else? Also one of brush connectors is broken and there is a slight grinding sound when the shaft is rotated (likely a bad bearing being that it's not an enclosed motor). Not too exciting all-in-all especially because I know nothing about motors or how to fix them.
The fellow tells me that the motor he sent is better because it is matched to a 40v controller in the back of the unit. I'm wondering why it would have had a 90v motor on it for the pic. then?
Q. Is there any easy way to tell what voltage the controller actually is as there was no documentation with the unit?
Besides the fact that this motor smells suspiciously like toast, my gut is
telling me that a 90V DC motor probably offers more umpfh (torque?) than a 40v does anyway.
Q. Is this correct or not?
He's offered to send me the 90v motor if I return the 40v one first (more cost) but says it would run at only 4/9ths of its potential (seems logical) with the 40v controller, if that's what it really is.
Assuming there is no desire to get into a protracted disagreement here and also recognizing that my budget is very tight (I'm on a small disability income):
Q. In terms of the motor, what are my best options and what would you do under these circumstances (besides taking him to task) if your primary objective is to get it up and running well without throwing lots of money at it?
Thanks kindly,
- Gerry
