586,666 active members*
4,543 visitors online*
Results 1 to 6 of 6
    49
    G91 B axis move?
    Hi all can anyone give me a reason why I would get a improper G code alarm when all I want to do is move the B axis away from the part after it is cutoff in a G91 move I have the sample blocks of the program below any help I would be grateful , this is a Fanuc 18i controller on a Doosan 2500 lsy.
    O7000
    N100G0G90G40G80
    G28U0.V0.
    M1
    N900(CUTTOFF)
    M131(interlock by-pass sub spin.)
    M110(close tooling by-pass)
    M169T0200
    G0X1.762Z0.T0202B-27.5
    G4U100
    G98
    G1B-29.0F150.
    G96S600M4
    M204
    M168
    G99
    G1X1.43F.003
    G0X1.602
    Z.06
    G1X1.563
    G3X1.438Z0.R.0625
    G0X1.602
    Z-.06
    G1X1.563
    G2X1.438Z0.R.0625
    G1X-.03
    G91B.02(RETRACT SUBSPIN .02 BEFORE X AXIS MOVES UP. improper G code alarm )
    G0G90X8.0
    M205
    G28B0.
    Z10.M9
    G80
    M30
    2932
    As far as I know, there is no incremental command for B on the 2500SY. (X=U, Z=W, C=H, etc.), but there is no incremental B. You might consider using macro variables, instead of hard coded dimensions, i.e.:
    in #504, put -29.0
    in #505, put -28.98
    O7000
    N100G0G90G40G80
    G28U0.V0.
    M1
    N900(CUTTOFF)
    M169T0200
    G4U100
    G98
    G1B#504F150.
    G96S600M4
    M204
    M168
    G99
    G1X1.43F.003
    G0X1.602
    Z.06
    G1X1.563
    G3X1.438Z0.R.0625
    G0X1.602
    Z-.06
    G1X1.563
    G2X1.438Z0.R.0625
    G1X-.03
    B#505(RETRACT SUBSPIN .02 BEFORE X AXIS MOVES UP. improper G code alarm )
    G0G90X8.0
    M205
    G28B0.
    Z10.M9
    G80
    M30
    May 2007
    51
    Using a MS SL150smc I can confirm that there's no incremental axis for B.
    I use G0G53Bxx to be sure where my sub-spindle is locateted, no matter which datum thats currently active.
    Jul 2003
    263
    the lathes do not use g91 for incremental moves
    X = U
    Z = W
    Y = V
    C = H
    A = A
    B = B
    a xis for the mill mode on the subspindle and b for the subspindle
    i usually command G53B0 after part off then move the x out of the way
    the x will move even if the b is still moving
    If you can ENVISION it I can make it
    49
    I find it to be strange that Doosan would choose to not be able to move the B axis (sub spindle) in a G91 incremntal move when other machine builders do use the G91 move for the subspindle , we have a Viper VT 23 lathe that I can do a G91 move on the sub spindle . I will take your advice when I talk to the service people that we bought the machine from to make sure this is totaly true , thanks for your input.
    2932
    Your Viper is probably set to use G-Code System B or C, which switch between absolute and incremental coordinates with G-codes (G90/G91). Doosan uses G-Code System A, which uses address characters to switch between absolute/incremental (X/U Z/W C/H) but Fanuc (not Doosan) doesn't provide an incremental address for B. System A allows mixed absolute/incremental commands within a block, i.e. X & W, or U & Z... System B & C do not.
  1. What method did you use to move the x-y-z axis?
    By widgitmaster in forum Polls
    Last Post: 07-04-2013, 04:49 AM
  2. How do you move an axis manually ?
    By Eurisko in forum DIY CNC Router Table Machines
    Last Post: 04-07-2007, 03:00 AM
  3. Axis move during feed hold
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-12-2006, 04:12 PM
  4. Mach 1 x-axis will not move
    By Redline in forum Mach Software (ArtSoft software)
    Last Post: 07-05-2005, 06:01 AM
  5. Speed how fast an axis can move?
    By jlagran he in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2005, 05:05 AM
