586,036 active members*
3,446 visitors online*
Results 1 to 6 of 6
    Sep 2006
    21
    Ballscrew/Ballnut question
    I have a KURODA GE 15-10 ballscrew ballnut combination. I need to turn the ballnut around so the flange is facing the other way. What is the procedure for removing and replacing the ballnut without ending up with the balls rolling around on the floor?
    Dec 2006
    532
    In the picture in link notice the carton tube, find one that has similar/same diameter of your ballscrew, and rotate the nut onto the tube. Check also the second link to see what i mean.
    http://cgi.ebay.com/NOOK-SBN-8278-BA...QQcmdZViewItem
    http://video.google.com/videoplay?do...arch&plindex=0
    Sep 2006
    21
    Thanks!! I think I get the idea.
    Aug 2007
    45
    ballscrew size
    Hi guys..
    I am going to look for a ball screw for my router. I have not purchased the motor yet but I want to complete the ball screw first before moving on to the motor.
    1. I am thinking of using 12mm diameter ballscrew. Pitch will be around 5 to 10mm lead. If I can get 5mm lead is better but slower.
    The question is, do you think 12mm diameter is strong enough?
    Do I need larger diameter? The max length is only 32inches.
    Here is a little information for the required length
    For X = 34 inches
    For Y = 26.5 inches
    For Z = 13 inches
    Nov 2007
    27
    Ballscrews
    Hello Dex,
    Strong enough yes, will it whip at high RPMs is the questions.
    A 12mm diameter should be fine on those spans. However, it all depends on what you want your feed rate to be. With a 5mm lead, if your feed rate is somewhere around 100-150 inches per minute (254-381 cm per minute), then that diameter will be fine. However, if you are wanting high feed rates like 250 IPM (635 cm per minute) then you may need a larger diameter, but would still probably be fine as your unsupported span is even less than 32 inches.
    I have a link to a chart that references RPM vs allowable lead screw length and diameter, but I can't find it. When I do, I'll post with a more definite answer.
    Nice looking machine by the way!
    Keven
    [email protected]
    www.cncroutersource.com
    Aug 2007
    45
    Hello Keven,
    Thanks for the explanation. I'll look forward to you link.
    At the moment, I can only use 12mm screw for the Z axis as the space for the lead nut is limited.
  1. Ballscrew bearing question
    By pstockley in forum Mechanical Calculations/Engineering Design
    Last Post: 05-16-2006, 10:21 PM
  2. Ballscrew pitch accuracy question
    By pstockley in forum Linear and Rotary Motion
    Last Post: 04-23-2006, 11:32 AM
  3. Ballscrew Noob Question
    By BobWarfield in forum Uncategorised MetalWorking Machines
    Last Post: 01-24-2006, 08:41 PM
  4. Need a ballscrew and ballnut
    By trungsy in forum Linear and Rotary Motion
    Last Post: 10-29-2005, 12:34 PM
  5. Router Ballscrew Bearing Question
    By jjwl89 in forum DIY CNC Router Table Machines
    Last Post: 07-23-2004, 01:24 PM
