586,070 active members*
3,543 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > SCM Record 1 manual, infos, downloads ?
Page 1 of 2 12
Results 1 to 20 of 32
    Nov 2007
    Hi, as i mention in the post below, we bought used SCM Record 1. This is our first CNC center and we have no experience.
    The problem is: we don't have documentation, the prorgramms, but only electical sheme.
    Maybe some one know where i can found it or send it per email?
    Google search does't bring much.
    Nov 2007
    4
    scm record 1 manuals
    Hi have just joined the forum.
    We have got a second hand record 1 and have a parts manual and all the NUM 720 manuals if you still need them.
    regards Asterix13
    Nov 2007
    Hi i have been running a record on for the past 10 years. I have parts. num 720 manuals postprosesor for alphcam and a lot of experience.
    regards p_ken
    Nov 2007
    4
    Hi p_ken,
    Nice to hear from another record owner, can you help with this problem I have.
    I have been running the scm record 1 for around 6 months but have been unable to get the drip feed working. Following the instructions from the NUM 720 manual does not work.
    So I can only run very small programs + - 1200 lines of code
    Nov 2007
    4
    Hi p_ken,
    Nice to hear from another record owner, I have been running our scm Record 1 for the last 6 months using AlphaCam but can not get the drip feed to work. The NUM 720 instructions do nothing so I can only run small file sizes + - 1200 lines of code. This means I have to run jobs broken in small lots. Can you help?
    Regards Asterix13
    Nov 2007
    Hi Asterix13
    I have drip fed programs some time ago but cant totaly remember how.. we increased the memory. I will hunt through my notes and try and recall the process.
    Jan 2008
    Record manual
    Quote Originally Posted by P_Ken View Post
    regards p_ken
    Hi p_ken,
    we recently bought a used scm record 1 (1997) as a second machine for 3-axis jobs and are also missing the manual. Would you mind to send me a manual as well?
    Thanks a lot in advance
    Nov 2007
    4
    Smile Num 720 Manuals
    Quote Originally Posted by fictionist View Post
    Hi p_ken,
    Hi fictionist,
    Let me have your e-mail details and I will send Num 720 manuals to you.
    File size for 720 is about 14meg.
    I also have Num 820 if needed.
    Do you use drip feed on your machine?
    Regards [email protected]
    Jan 2008
    Quote Originally Posted by asterix13 View Post
    Hi fictionist,
    Thanks a lot for the quick response. My email address is [email protected]
    Regards form the sunny Cape Town
    Jul 2009
    regards Asterix13
    Hi p_ken,
    we recently bought a used CNC machine and are missing the manual.
    Would you mind to send me a manual ?
    My email adress is [email protected]
    THANK YOU VERY MUCH!
    Jul 2009
    Hi p_ken,
    i am a member of CNCzone.
    my email adress is [email protected]
    Thank you very much!
    Jul 2009
    num720 manuals
    Hello everybody,
    I also need a copy of num720 manuals in english.
    My e-mail is [email protected]
    Greetings from Greece
    Thanks a lot
    Jul 2009
    22
    Xi log and Xi log plus
    Hi All,
    Does any of you lot use Xilog or Xilog plus.
    If you need any help just give me a shout regarding Xilog or Xilog plus.
    Also I have an alphacam post processor for the NUM 720, NUM 750, also for the RECORD 220 I have two post procesors.
    You might need to tweek them.
    Shaun
    Feb 2007
    25
    Quote Originally Posted by shaunbirm View Post
    Hi All,
    Shaun
    Hi Shaun,
    Do you drip feed to your SCM? I have a Record 2 and am using Ezcam Software. I can send files no problem at all but drip feed has been ongoing issue for the past 12 months. if you have any advice I would be most appreciative.
    Cheers
    Chris
    Jul 2009
    22
    Hi Chris,
    I don't use drip feed.
    The programs i use are stored on a server called (k drive).
    I don't store any programs on the control.
    When the programs are opened up in panel mac and run they are actually all still on the server and the programs run fine.
    To do this all you need to do is put your control on the network and access is dead simple
    If you need more info let me know and I'l do a demo.
    Shaun.
    Sep 2009
    5
    If anyone has the programming manual for NUM720f i would be very grateful.
    Email: [email protected]
    Best regards
    PS: What kind of a PC and software would be compatible with the Num720f for program storage and easier input? The machine is from Greda
    Jan 2010
    i have been running a record 120, and i have hypermill open-mind version 9.6.
    i need a postprosesor.
    can you help ?
    Apr 2008
    Hi Shaun,
    I am working on a Record 220 & would certainly like an Alphacam post if you still have one.
    Alan
    Jun 2010
    Looking For Manual
    I have a problem qith a record I qith num 720, i looking for manuals.
    Facundo
    [email protected]
    Aug 2010
    Raphael Huber from Switzerland is behind SubConsciousMind or short SCM. In 1997, with no musical or technical experience and having no one to ask, he started to teach himself everything he needed to know by simply tweaking till it sounded like music. Since then he has performed live internationally, released two and a half albums and carefully developed his own edgy and characteristic style.
Page 1 of 2 12
  1. Scm record 220 with NUM 750 Manual
    By harrisres in forum Commercial CNC Wood Routers
    Last Post: 06-02-2021, 08:58 PM
  2. Hurco KMB1 Manual Downloads
    By Snipes44 in forum HURCO
    Last Post: 08-24-2014, 03:33 AM
  3. A new Site dxf-downloads.de
    By cad_freak in forum WoodWorking Topics
    Last Post: 09-10-2012, 05:24 PM
  4. CAD/CAM Softwear Downloads
    By matsci1 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-28-2010, 05:45 PM
