586,102 active members*
3,274 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach 4 > Can Mach4 send basic Galil Commands to the Galil Controller? Like SH or MO, etc?
    Apr 2010
    18
    Can I send a SH (Servo Here) or MO (Motor Off) Galil command from within Mach4? Ideally I'd like to assign it to a button or include it in an existing button script. Has anyone done this or can point me in the right direction? I'll reply back here with my experience.
    Board is Galil DMC-2183
    Software is Mach4 with the Galil plugin
    drives are Baldor TSD DC Servo
    motors are Baldor MK-2250 DC Servo
    thanks,
    Brian
    Nov 2013
    4375
    Re: Can Mach4 send basic Galil Commands to the Galil Controller? Like SH or MO, etc?
    HI,
    I dont use Galill but use Mach4 and an ESS.....and yes sending basic commands like switching an input on or off is pretty basic and Galill should certainly do so.
    For example my Delta servos require an active RESET signal in the event that they ever fault out. If I need to reset a servo I have an on screen button that I press and that in turn
    sends a signal to the ESS which in turn sends a RESET pulse to the servo drive via my breakout board.
    Craig
    Mar 2004
    1543
    I know its not cheap but Camsoft is the control to use with Galil cards. It is build specifically for this.
    I have used Camsoft over 20 years now on five machines.
    Apr 2010
    18
    I'm investigating CamSoft. Price is tough to handle for a hobby...it better work for the $$$$$$$$$$$
    Nov 2013
    4375
    as I posted earlier I've been using Mach4 for eight years....it works. You may have to do a little research to get it to communicate with the Galil......but it too will work.
    The lead developer of Mach4 is Steve McMurphree, and also happened to be a longtime employee of Galil. The Galil plugin for Mach4 was written by Steve.
    Reach out to him on the Mach4 forum and you will get the answers you require....or spend big dollars on Camsoft....your choice.
    Craig
  1. Galil Servo Design Kit / Galil Suite
    By Neo20X in forum Controller Cards
    Last Post: 03-12-2013, 11:31 PM
  2. galil motion control with visual Basic 6.0 activeX
    By servomec04 in forum Open Source Controller Boards
    Last Post: 03-05-2012, 03:42 PM
  3. Replies: 13
    Last Post: 06-28-2010, 03:49 PM
  4. Galil motion controller question
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 07-22-2007, 10:24 PM
  5. Galil & Visual Basic?
    By Al_The_Man in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-17-2006, 07:32 PM
