586,096 active members*
3,112 visitors online*
Results 1 to 3 of 3
    Arcs in Z axis
    I've been writing my own code for the last several months and have MS Excel setup parametrically. I have the input data (usually just part type, ID code and part length and width) in a few fields on one sheet, calculations on another then the sheet with the actual code on another. That way I can just type in the part info in a few cells then the entire 100 - 600 line program gets updated and ready to copy to the text editor and feed my machine. I'm saying this because a modeling program is out of the question since I can only model one size at a time.
    I intend to start making doors using "round-end tenons" which are just like regular tenons but with ends the same radius as my tool that cut the mortise slot. I'll do this with my 90 deg aggregate head with, for example a 3/8" mill tool. I just watched a video on cutting arcs in the X-Y plane and it seems simple enough but as you can imagine I need to do this in the Z axis. Can anyone describe how this is done?
    Cheers!
    Aug 2009
    1573
    Re: Arcs in Z axis
    ...the G code for Selected Plane is normally defaulted on Mills is G17 XY and is modal.
    G18 is for XZ (Lathe default)
    G19 is for YZ
    how to program Arc Centers and G2/G3 may help to read this from Linux coding.
    https://linuxcnc.org/docs/html/gcode...ml#gcode:g2-g3
    Jun 2015
    4154
    Re: Arcs in Z axis
    hy heirloomwindows i can help with automation from input to g-code, like to make it faster & better than excel, and however you wish
    if you have some idea, or whatever thing to improve, feel free to contact me; i can generate models&codes from custom inputs, etc / kindly
  1. Help with g2/g3 arcs during axis rotation!
    By GTFreeFlyer in forum Mach Mill
    Last Post: 10-09-2012, 09:22 PM
  2. Incremental arcs and Break arcs into lines
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 09-16-2010, 04:55 PM
  3. Z axis arcs
    By dblox in forum Dolphin CAD/CAM
    Last Post: 09-03-2010, 01:33 PM
  4. mitsubishi fa20 wedm 4 axis arcs
    By jelmerra in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-23-2007, 07:07 PM
  5. Code with Vertical Arcs, and 3 axis travel help
    By GTmike400 in forum G-Code Programing
    Last Post: 04-21-2006, 11:06 PM
