586,117 active members*
3,510 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 4020 all axis fault??
Results 1 to 9 of 9
    Oct 2020
    17
    On initial power up wherever the selector knob is for jog, X,Y or Z it gives an alarm. If you move the selector to a different axis it will alarm out that axis. Screen message amplifier fault. Point my in a direction please.
    Aug 2009
    1573
    Re: 4020 all axis fault??
    ...low input Voltage? Low air pressure? wow that is weird thing happen.
    Oct 2020
    17
    208vac input all three phases.
    Oct 2020
    17
    208vac input all three phases. 120psi to the regulator.
    Aug 2009
    1573
    ...in SETP there is a 5% low voltage setting...could maybe try that.
    Oct 2020
    17
    Quote Originally Posted by machinehop5 View Post
    Already tried that. The machine that is 5ft away runs just fine.
    Oct 2020
    17
    reskinner? Any ideas? It's almost as if the amps are not even being turned on.
    Aug 2009
    1573
    ...try calling these guys...they helped me on the phone hooking up a 4th axis for no charge. Great Folks
    For Help, Call or Text (406) 600-0624
    https://nxgenparts.com/axis-amplifiers/
    good luck,
    DJ
    Quote Originally Posted by swatsonMPM View Post
    check power supply voltage
    12v and 5v
    input 120v ac
    check jumpers on transformer for correct output voltage
    check blue capacitor voltage between 125to160
    vdc depend on type of transformer
    check fuse f17 and k1 relay
    and finaly reset motor overload relay on amps chassis
  1. Replies: 4
    Last Post: 02-07-2018, 05:25 PM
  2. 4020 Spindle fault question
    By kentsui in forum Fadal
    Last Post: 11-01-2010, 11:46 AM
  3. Z axis Amplifier Fault on Fadal 4020
    By Fudd in forum Fadal
    Last Post: 08-29-2006, 11:01 PM
