586,113 active members*
3,252 visitors online*
    Nov 2022
    14
    EMCO VMC100 EMCOTRONIC TM02
    Hello, i am developing postprocessor for my customer for Emco VMC100 with Emcotronic TM02 controller. We have problem with helical motions with G2 G3. When there is Z changing in block with G2 G3 machine throws error 418 WRONG CENTER COORDINATE SPECIFIED. I checked the gcode and start and end points and I and J are ok. My question is to check if anyone have sucess to run helical motions on this machine and if you can share gcode example thank you in advanced.
    Mar 2016
    325
    Re: EMCO VMC100 EMCOTRONIC TM02
    I'm not sure but TM control may not be able to perform helical interpolation.
    Aug 2009
    1573
    ...program Format would be something like G2X...Y...I...J...Z...F30. for most normal Helical moves for CNC machines.... Unknown if, your machine has Helical capability.
  1. VMC100/TM02 memory backup battery?
    By Viilari in forum EMCO Mills
    Last Post: 09-22-2020, 06:35 AM
  2. EMCO VMC100 TM02, MSD to tape?
    Last Post: 09-14-2020, 08:26 AM
  3. Replies: 1
    Last Post: 12-30-2018, 09:27 PM
  4. Emcotronic TM02
    By stefannils in forum Want To Buy...Need help!
    Last Post: 01-05-2018, 11:21 AM
  5. Need TM02 (VMC100) Main Drive Board
    By calmissile in forum EMCO CNC Machines
    Last Post: 11-08-2013, 05:40 AM
