586,089 active members*
3,915 visitors online*
Page 1 of 2 12
Results 1 to 20 of 30
    Sep 2005
    140
    Dual Vee Wheels
    Anybody got any experience building a router using these wheels. Please tell me how it worked out and show some pics if you can.
    Walt
    This one here used them. Unfortunately, all the pics in the thread are gone.
    http://www.cnczone.com/forums/showthread.php?t=33124
    Jan 2006
    357
    Apr 2005
    3634
    Oct 2006
    735
    http://www.cnczone.com/forums/showth...t=wcarrothers1
    Don't know if these are the type of V wheels you are thinking about how ever I can say they work well on my machine
    b.
    Sep 2005
    140
    Yeah those are the ones, what do you guys think of this for x and y made out of MDF and Angle iron.
    Oct 2006
    735
    While I believe the ones I have are dual row bearings I would not consider them lateral contact races. By that I mean loading them sideways the way you are may not exactly be the direction they have the most support. having the load to their shaft is the way they are suposed to ride far as I know. They might have a chart you can figure out what their vertical vs sideways loads are rated at.
    I would not do it like that my self.. I'd make them ride as I did.
    b.
    Oct 2006
    735
    Also the larger ones like I used are not all that cheep (depending on how lucky you get getting them) so keep in mind they add up (cost wise) quick...
    b.
    How do you mount a spindle to that?
    I do like the horizontal rail idea, though. I may incorporate that for the X rails on the machine I'm designing. Looking at the BWC catalog, it looks like as you widen the rails (from angle to angle), the axial load decreases, if the load is in the center. After some quick math, it looks like as you double the width, the axial load decreases by half. The #2 size rollers are rated at 140lbs axial load.
    Based on the formulas I see in the catalog, a 200lb load gantry, with the load centered on the carriage, with the rollers axles at 4" OC (2-5/8" across the points of the angles), would give an axial loading of about 38lbs/wheel. Well below the 140lb rating.
    Unfortunately, where the loads are actually coming from during motion is a bit more tricky to figure out, and not so simple. And feel free to check my math. Download the catalog at www.bwc.com
    Sep 2005
    140
    So what would you do different to make it a viable idea? As far as mounting the z I would mount it to the carriage on the y axis.
    Sep 2005
    140
    I am not done with the drawing, I was just playing around today and came up with that. The best way to mount the z might be to turn the y on its side and build a torsion box. I am no engineer, Just want to build a nice router and looking for ideas.
    Walt
    Sep 2005
    140
    I know not the best drawing but how bout something like this? you could use rollers on both the top and front to keep the z from any movement.
    Walt
    May 2003
    323
    Vee wheels
    Sir,
    Attached are some pix of my Z axis usiing vee wheels. We used vee wheels and hardened ways for X and Y axes of one of our smaller machines (production work) and they did well.
    Regards,
    Jack C.
    Attached Thumbnails Attached Thumbnails DSC00042.JPG   DSC00046.JPG   DSC00136.JPG
    Oct 2006
    735
    I still think making the X bearings ride on their side like that is not the best idea becides it makes the machine much wider then it would otherwise have to be if they were upright.
    Course after thinking about it you can say that yours are now taking the lateral loads that the router will put on them when running and just have to carry the weight sideways.
    Course in my design I was going to put 3 bearings in (one above and one below as I currently have then another faceing 90deg to those on the rail to deal with the lateral loads. How ever I never put them in because it would have made things more complex especially while trying to adjust height and calibrate the machine then I though it would need to be and I don't think at this point it would have been better with them.
    b.
    Oct 2006
    735
    b.
    Sep 2005
    140
    What do ya all think?
    What do you think of this. Uses DualVee's the y axis carriage will use 2 vee rollers at the top back and 2 on the front bottom, with z mounted to it.
    Walt
    Nov 2007
    27
    Walt,
    I like this design for the X-axis much better. Agreeing with many of the people here, the dual Vee's are designed to carry the load through the axis. Of course the wheels can sustain a certain amount of lateral load which will vary depending on their rating.
    The wheels would probably not fail under these loads. However, the axles and the structure supporting them would be under constant stress from the moment (torque) that the lateral loads would cause.
    This could deform the inner raceways of the V-wheels or something else which could cause slop in the system over time.
    I am still unsure of what you mean by the Y-axis design. Also just curious, what is you major reason for using V-wheels? Not that thats a bad thing, just curious.
    Keep up the good work, its getting there!
    Keven
    WWW.CNCRouterSource.com
    I think you might get some flex, due to the slot that the nut goes through. It would be better if the rails were solid.
    Nov 2007
    27
    Walt,
    This is true solid is always better. If you give me the dimensions, material, and an estimated gantry weight, I can stress it for you and quickly tell you how much "flex" or deformation you will encounter.
    That goes for any of you!
    Keven
    Sep 2005
    140
    Well, the reason for the DualVee wheels, I dont really have one. I have been trying to come up with a router that I can build with my existing tools that I have at home(tablesaw, router, CNC'd Minimill. I have looked at Joe's and it looks great but I haven't had any success building accurate parts with my home tools. The minimill travel is just to small. So I am just trying to come up with something that can be built easily and still be accurate enough to build something better. Does that make any sense at all? The DualVees looked like they would work fairly well and they still would not cost as much as buying linear rails etc.
    Maybe I am barking up the wrong tree though, I am open to suggestions.
    Your input is greatly appreciated!!
    Walt
Page 1 of 2 12
  1. ULS wheels
    By Jim Huston in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-19-2006, 04:55 AM
  2. Source for v-wheels
    By vid1900 in forum Linear and Rotary Motion
    Last Post: 11-08-2006, 06:32 PM
  3. Dual Vee Wheels
    By Rypper in forum DIY CNC Router Table Machines
    Last Post: 10-11-2006, 11:36 PM
  4. ? about jog wheels
    By mdreitzusa in forum Benchtop Machines
    Last Post: 05-18-2006, 09:49 AM
  5. skateboard wheels for vee wheels...
    By lurch in forum Linear and Rotary Motion
    Last Post: 10-02-2005, 05:10 AM
