586,103 active members*
3,304 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Several input for triggering emergency stop.
    Jun 2017
    119
    Hi.
    I have recently added a floating head with a breakaway torch. This is with a pnp sensor which I have connected to input 4. This works okay and the input is triggered when I remove the torch.
    However I would like this to trigger a emergency stop if the torch were to fall of. But I can't find any place to add this in the TNG software.
    Is there a way to specify that the input should trigger a emergency stop?
    Aug 2020
    131
    Re: Several input for triggering emergency stop.
    I do something similar for monitoring my 4th axis,
    you can trigger the estop from the expr.txt
    this is what I do for my 4th axis:
    #OnInit
    state_estop_4th = 0;
    #Loop
    if(_hw_input_num|3 == 1&& state_estop_4th==0, exec(state_estop_4th=1,estop(1),print('4th Axis error')));
    if(_hw_input_num|3 == 0 , exec(state_estop_4th=0));
    Jun 2017
    119
    If I understand it correctly this is a script running in the background?
    #Oninit means on startup or start of program it checks the value of the input?
    #Loop means that the script is running continuously throughout the program and if triggered will throw a "4th axis error" on the screen?
    Should have been a easier way than this, if I don't remember incorrectly you could chose what the inputs meant in the old software without limitations.
    Quote Originally Posted by ScorpionTDL View Post
    #OnInit
    #Loop
    Aug 2020
    131
    Yea you got that correctly.
    Don't know if there is a other more easier way. But this has been working fine for more.
    Jan 2022
    107
    You may assign a single input pin in settings -> Shortcuts to the emergency stop, but i personally prefere the same way ScorpionTDL suggested. This way you have more flexible options for displaying messages or use pins which may not require e-stop but triggering pause or regular stop.
    I use e-stop for errors from motor drivers, regular stop if spindle is overheated and pause if air pressure is low or tool temperature is high. All depending if i think a short delay is ok or not and if there may be a chance to fix the error and resume operation without actually interrupting the program..
  1. Problems with Emergency Stop/Stop function.
    By MrEmo in forum PlanetCNC
    Last Post: 10-19-2021, 10:47 AM
  2. emergency stop condition after E stop
    By Cosmin90 in forum Fadal
    Last Post: 01-14-2020, 01:30 AM
  3. E stop triggering
    By technetics in forum K2CNC
    Last Post: 07-26-2016, 10:27 PM
  4. Generic Emergency Stop (E-Stop) Design Concepts?
    By zipzit in forum CNC Machine Related Electronics
    Last Post: 06-09-2011, 12:14 PM
  5. Physical Button Signal Input Triggering Macro
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 08-25-2006, 04:26 AM
