586,103 active members*
3,910 visitors online*
    5/16" (8mm) Cutting Issues
    Hello!
    I recently was put in charge of programming our 4k Mitsubishi Fiber laser and we are currently running into an issue with cutting parts. We have the parameters set to fully cut the parts, but occasionally the part will not cut all the way in a random spot causing us to lose roughly 20% of parts. While they are small parts it still is frustrating as I would like to utilize lights out with them as there is a massive quantity needed. Here is a list of things we have troubleshot to isolate the issues.
    - Lead in was perfectly centered
    - Mode shot came back clean
    - Programmed for the machine to skip around on the program to minimize heat
    - Checked nozzle size and roundness
    - Going to try pre-piercing on our next run to see if that helps minimize heat as I think this is the issue we are running into.
    I'll attach pictures of our parameters as well as what the part is doing when cutting. Anything suggested will be appreciated as this is becoming a thorn in our side.
    Thanks in advance!
    Attached Thumbnails Attached Thumbnails image_67151105.jpg   image_67178753.jpg   image_67146753.jpg   image_67167745.jpg
    Re: 5/16" (8mm) Cutting Issues
    Attached the wrong picture for the cut out. Here's the backside of the part.
  1. Help...Issues with perpendicularity of 8mm hole.
    By houghtont0520 in forum MetalWork Discussion
    Last Post: 04-08-2015, 03:26 AM
  2. true 2" (50.8mm x 50.8mm) steel square tube in Australia?
    By jazza in forum Australia, New Zealand Club House
    Last Post: 07-07-2013, 01:09 AM
  3. Problem cutting 8mm stainless!
    By sjclaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-20-2013, 09:18 PM
  4. Powermax 65 cutting steel 20 ga "0.8mm"
    By titto in forum Hypertherm Plasma
    Last Post: 01-25-2013, 02:53 PM
  5. Laser/Waterjet SS 316 5-8mm (0.27/0.33) and 8mm (0.33) Polycarbonate
    By rugludallur in forum Employment Opportunity
    Last Post: 03-15-2010, 11:51 PM
