586,075 active members*
3,684 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Copied file not recognized on other lathe
Results 1 to 9 of 9
    Aug 2023
    6
    Unhappy Copied file not recognized on other lathe
    Hello,
    -Copied files to USB from Lathe with OSP P300L controller
    -Import files to Lathe with OSP P300LA controller
    -Try to open the files and get an error with file number (not comfortable)
    -Tried different USB stick
    The P300L does have a steady rest, while the P300LA does not. Could this be the cause of the issue? We were able to import other files that use the steady rest.
    Copied 3 files, one works as intended while the other 2 come back with this error.
    Any help would be very much appreciated.
    Thank you
    Dec 2008
    3109
    Re: Copied file not recognized on other lathe
    What is the full name & extension you are using ? (ie ABC123.MIN)
    What is the error ? ( This should answer everything )
    What do you mean "not comfortable" ?
    .... machine type (control you name), error number, 2 lines of text after the error number
    .... or a good jpeg of the screen showing error
    Aug 2011
    419
    You can copy part program files (.MIN files) but probably you can't edit IGF files in another machine because they are related specs or igf version.
    "Imagination is more important than knowledge."
    Mar 2009
    1982
    Sure, the very first question is if these are part program files (.MIN). There is no point to copy other than part program (.MIN) and schedule program files between Okumas. Part program files can work on other machines also, after allignment with their specification.
    if yes, you can locate the fragment of the text which is not comfortable.
    Jun 2015
    4154
    hy i can take a look, so please share those 3 files, and the error / kindly
    Aug 2023
    6
    Sorry and thank you for replying to my inquiry. The error was "File No. UNCONFORMABLE" I am not a CNC guy, just trying to help my Co-workers I'm a Fanuc welding robot guy :P
    Dec 2008
    3109
    Quote Originally Posted by crweld View Post
    So... a Fanuc guy, what is the full error explaination ? As it all helps to point out the issue.
    Later controls may have "HELP" key, press it when the error is active, it should display the solution.
    Are you trying to use a file name like the Fanucs use ? Ie O1234.NC
    Try using Okuma naming rules
    Ie ABC123.MIN or A.MIN
    Letters before numbers, no double Os etc.
    .MIN is the extension for the machine code (like .TAP or .NC)
    Jun 2015
    4154
    please, if possible, share those 2 errored files, or at least a photo of filename, or specify extension
    Aug 2023
    6
    The file extension is ".PET" I cannot get a picture currently as the lathe is in full production of other parts.
    Aug 2023
    6
    Thanks I understand my question is vague and I did not provide enough details. They are using files with a .PET extension.
    Jun 2015
    4154
    hy crew i guess you are that guy with good windows skills, also good at fanuc robots + more
    i am sorry, pet files are not always compatible between machines; it seems an easy way to transfer programs, but they do not hold only operations, as also machine specifics
    but if it did not work one way, try from the other machine to the 1st
    if this fails, don't discourage, there are still solutions / kindly
    Aug 2023
    6
    This makes the most sense, the problem occurs when the unit with a steady rest makes an edit to a file, the newer unit without a steady rest will no longer recognize the file. I had proposed that could be an issue but the guys weren't sure. Thanks from, the good with Windows dumb with CNC guy
    Jun 2015
    4154
    hy crewld i sent you a private message on industry arena, like attached ... pls check it
    yes, and there is more : for example, you may have 2 lathes with same configuration, and not to be possible to transfer *.pet between them, or maybe only one way, like between one machine to the other, but not viceversa
    pet files are a product of igf software version; igf itself is specific to configuration, but also, the pet file, is not just a simple save data file, but an *.exe undercover ... so a simple change in igf, triggers much more many changes into the pet file, like if you change, for example, feed from 0.15 to 0.16 in igf, then the pet file will change not only with 1 char, but much more, in many places, non consecutive
    you are not the 1st to hit into pet files compatibility issues
    Thanks from, the good with Windows, dumb with CNC guy
    everything can be learned / kindly
    Jun 2015
    4154
    even more, an update of actual machine, may render all existing pet files as incompatible with the last install
    thus old configuration related igf work, no longer available / kindly
