586,430 active members*
4,064 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Novakon nm-145 conversion to Centroid (Acorn)Acorn?
    Feb 2009
    51
    If anyone has converted the NM-145 mill to use acorn (Centroid) electronics, please let me know your details to get it all running.
    Steve Bell
    Jul 2011
    400
    Re: Novakon nm-145 conversion to Acorn?
    I did not convert a NM-145 but I did convert a Torus pro. Is there anything specific you need to know?
    An acorn is a good upgrade. I will never use Mach 3 again.
    Feb 2009
    51
    In the meantime, I need to keep the machine running, but MACH3 now needs the correct XML file for the Novakon NM 145.
    What may have happend is that the backup xml had been corrupted, along with the file that had recenly been in use.
    I need a proper xml file for the mill until any conversion to another mill driver would be implemented.
