586,112 active members*
3,005 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Onlinestepper T6 Servo on Bridgeport
    Sep 2016
    26
    I am new to the servo game and I was wondering what I have to do to set up the drive for a Bridgeport. Tuning and parameters. Do's and Don'ts!
    Nov 2013
    4376
    Re: Onlinestepper T6 Servo on Bridgeport
    are you replacing existing servos or are you starting from scratch?
    If replacing servos then I imagine you'll want servos and/or drives that match the existing control system. Then the issue is 'what is that control system', as many
    modern AC servos and drives are not well suited to old, or rather earlier generation control systems.
    Craig
    Sep 2016
    26
    Craig
    Moving from stepper motors to servos. Just no clue what to do.
    Dec 2013
    5717
    The Onlinestepper T6 Servos seem to be step & direction only, so you should be able to use the same control as you were using for your steppers.
    Do's
    Follow the instructions in the documentation for your servos.
    Tuning instructions are in the documentation. Normally there is an auto-tune procedure.
    Don'ts
    Do not mechanically connect the motors to the ball screws until you are sure you have the servos under computer control and know what to expect.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2016
    26
    Why would it pause four times during bore or pocket? Plus the hopes are still not round.
  1. Bridgeport servo system
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2012, 04:28 AM
  2. Bridgeport y axis servo mount
    By kosmo in forum Bridgeport / Hardinge Mills
    Last Post: 04-12-2011, 12:47 AM
  3. Bridgeport series I Servo II help
    By Shop junkie in forum Bridgeport / Hardinge Mills
    Last Post: 07-08-2008, 04:01 PM
  4. Bridgeport Series II servo sizing?
    By PeteZ28 in forum Servo Motors / Drives
    Last Post: 12-22-2006, 02:44 AM
  5. looking for help with Bridgeport servo
    By boringmill in forum Bridgeport / Hardinge Mills
    Last Post: 08-22-2006, 02:44 PM
